I just wanted to mention that I had been doing a deeper dive into the 2GR-FE and all the common issues that have been present throughout the iterations. One specific channel on YouTube has been really fantastic at covering all the issues. Figured you guys might wanna binge some of them as well.
The most recent one I watched was released today and covers the oil cooler lines that used to be made of rubber and would harden and crack and dump the entire engine’s oil out. It’s been since rectified with a metal line, I even went and skipped through a factory tour video to see if I could find the upgraded oil cooler lines — sure enough they’re there!
UPDATE: I've started a spreadsheet of 2GR-FE issues and their potential impact to the Emira.
Some of the columns need explaining:
- Issue: Short description of the issue
- Engine Severity: The severity the issue poses to the engine, Critical, Major, and Minor
- Summary: Description of what fails
- Cause: Why the failure occurs
- Preventable via Maintenance: If the issue can be prevented with maintenance
- Addressed: If the issue was addressed by Toyota and what year it was addressed.
- Remedy: What is done to fix the issue
- Applicable Severity: The severity of the issue as it pertains specifically to the Emira
- Severity Notes: May include some notes as to the rationale behind the Applicable Severity
- Source: Any links I may find important
