A/C Vibration???
LuckysDad
Anyone else's car have a noticeable increase in vibration at idle when the air conditioner is on?
I haven't with mine. I was out today in 85 degree heat with the A/C on, and didn't notice anything unusual, although that sort of thing is common on small displacement engines. The A/C compressor adds load to the engine, so sometimes it will do that. Normally the idle speed is increased slightly to compensate. How many miles do you have on your car?
When you turn the A/C on does it sound like the idle is a bit lower than normal? Can you record a sound file of it?
Idle stays the same.
I don't hear any difference with the AC on or off.
Just feel a noticeable vibration at idle when it's on.
The idle is completely smooth with it off.
So you don't hear it, you only feel it. Hmm. I don't know, doesn't sound serious but I guess it wouldn't hurt to have the dealership look at it. If they have a demo car there, see if you can test it with the A/C on to see if it does the same thing yours does.
That's a good idea. I think I'll run over there tomorrow to see if their demo does it too.
I was out yesterday and specifically checked this when driving. It was hot and the A/C was on (which works great by the way). I noticed a very slight vibration in the shift lever when I turned the A/C on. I didn't feel it unless I had my hand on the shift lever. That's normal. Every car I've ever had you can usually hear and feel the difference in the engine (especially when idling) when the A/C is turned on, because the compressor adds load to the engine.
No unusual vibration on mine. If you turn on the AC and something seems to be shaking that you can feel through the body of the car, a dealer needs to look at the system. The compressor may be struggling.
Mine shakes at idle. The shake clearly goes away when I turn off the AC. It also idles lower with AC off, at about 700 rpm. With AC on it idles at 900.
Edit to add that my car had the AC resistor issue and fix.
Guys check my tread . This is what I got and it’s related to AC . I think my compressor needs to be replaced .
I have same issue and took it to the dealer couple of weeks ago and they couldnt find anything wrong.. but it clearly vibrate when the A/C is on at idle.. will changing the compressor fix the issue??
