interesting, also note the Evora GT 416HP vs Emira 400HP, so that might change the smog numbers.It's also interesting that the Emira has a better smog rating. The difference in gas prices from then to now really cranks up the fuel cost estimate.
You know I see that the sticker says 400hp but there are folks in the USA that have Dyno tested their cars after break in and were getting slightly higher numbers than the manufacturer states. Not huge but right at 416 crank based on the higher wheel numbers.interesting, also note the Evora GT 416HP vs Emira 400HP, so that might change the smog numbers.
I haven't seen this. What are the dyno numbers?You know I see that the sticker says 400hp but there are folks in the USA that have Dano tested their cars after break in and were getting slightly higher numbers than the manufacturer states. Not huge but right at 416 crank based on the higher wheel numbers.
