FS: Antigravity T6/L2 Lithium Battery, direct stock replacement, significant weight reduction
Kaz
$OLD
I got this great battery from GRP. Barely used mostly for testing for a few weeks it's working 100% perfectly, showing full charge and stable voltage. Comes with two remotes for the battery. Great way to lose weight off a perfect place in the car.
  • T6/L2 OEM Automotive Case size (directly replace stock battery).
  • LxWxH: 10.75 x 7 x 6.8 inches.
  • Amp Hour Options: 40 Ah, or 60 Ah.
  • High Power: 40Ah=1500CA, 60Ah=1800 Cranking Amps.
  • Exclusive RE-START Technology: Wireless Jump-Starting built-in; just press the button on your Keyfob remote.
  • Complete Battery Management System built-in.
  • Ultra Lightweight: Drop around 30lbs compared to the stock battery
  • Safest Battery Technology using full BMS and Lifepo4 Lithium chemistry.
  • Threaded Terminals: M8x1.25
PICKUP only in SoCal
**due to the AMG alternator programming, if you have an AMG I4, lithium batteries will NOT charge on drives enough to sustain long drives or without a trickle charger - V6 owners everything is fine
