Orchardbike
Active member
Has anyone got a Scorpion Tracker fitted to their vehicle? What are your thoughts, good idea or not? Does it drain the battery much? What discount did you get off your insurer?
Thanks SixSpeed. I believe you have to pay to have the Scorpion removed. Do you think it drains the battery much?I have the scorpion tracker and have an airtag. I don't really see much benefit over just the AirTag. I don't use any of the features on Scorpion.
No free years subscription as it was supplied via a third party.I have the Scorpion Tracker. Cant say I use it, but then, I dont want to be in a position to need to either. Not worked out if it saves much on the insurance yet, but will work that out in the new year.
As for battery drain, cant say either way, as it was installed when I got the car, so have no idea what the drain is like without. What I can say is that so far I have left the car for 2 weeks and it started fine. Have a trickle charger, that I use for durations greater than 2 weeks
If yours was installed by Lotus, you should get a years subscription with it, so dont see the point in not getting it setup. After the year, decide if you think its worthwhile
If you want it removed, you have to pay for an engineer to remove it. I’ve got the options of ‘pay to keep it’ or ‘pay to remove it’! I can of course just leave it, but was concerned that it is draining the battery as I get a low battery warning after two days.Not sure. My car hasn't had any battery issues. I wouldn't mind removing it though. I don't like that all data is recorded - but that could just be coming from the ECU.
Been running a factory fitted Scorpion since Hethel collection of my V6 FE Auto in August 2023. No battery drain issues and no need to trickle charge during garaged winter ‘off season’. Just made sure the 12v battery was fully charged beforehand.Has anyone got a Scorpion Tracker fitted to their vehicle? What are your thoughts, good idea or not? Does it drain the battery much? What discount did you get off your insurer?
I have the Scorpion tracker fitted. You can set it up for custom alerts. I have mine set to email me and have notifications on my phone when the car starts and for when the battery voltage gets low. There are many types of alerts you can set such as geo-fencing, speed limits, car movement without the engine running and odd hours to name a few.If you want it removed, you have to pay for an engineer to remove it. I’ve got the options of ‘pay to keep it’ or ‘pay to remove it’! I can of course just leave it, but was concerned that it is draining the battery as I get a low battery warning after two days.
Low battery warning in two days is not down to the Scorpion, unless it is faulty. Mine can sit for two weeks with no warning.If you want it removed, you have to pay for an engineer to remove it. I’ve got the options of ‘pay to keep it’ or ‘pay to remove it’! I can of course just leave it, but was concerned that it is draining the battery as I get a low battery warning after two days.
