eclat2emira
Hi, you may have heard Russell Carr and others mention this but wondered what they mean or why this happens? Is it because the silver is simply brighter than black (and the dual-tone diamond cut) so appears larger? Well there is probably a small element of this going on; when light hits the silver it will glow slightly and anything that glows - think of the sun or a light bulb - appears larger.
So that is the main reason when the silver is compared to the black - but not when it comes to the diamond cut.
I've shown below in a side-by-side comparison why the silver wheel appears larger than the diamond cut wheel: It's because the height of the silver area on the diamond cut wheel, when measured across the rim at the mid-point of a silver section to the mid-point of opposite black section actually is smaller than the wheel's diameter, giving the impression the entire wheel diamond cut wheel is smaller. This varies slightly depending which part of the wheel you measure the diameter across - but it's the main reason for the silver wheels appearing larger. If this was a mystery to you - now it's solved!
