3rd set of rotors in 11,000 miles
SelectmotorosportUK
New member
Newbury
Hey guys,
My Names Matt I'm the owner of a company called Select Motorsport LTD based in Newbury, UK.
We recently had a long term custom approach us about going through standard rotors like no tomorrow ( not because of wear, from drilled hole cracking due to high stress risers)
photo below showing cracking on both front and rears.
We have developed a full set of 2 piece rotors that will replace the standard rotors like for like. Designed and manufactured in the UK, using 6061 aluminium and hard anodised to finish.
These will not only cope with the heat better, they will outlast more than double the time of the standard rotors so a much more economical process if you are using your car on track a lot.
We've had one set produced and tested at this moment and would like to gauge on the forums if there's any interest? as I can provide a much better price the more that get manufactured.
At the present the cost of these for a full set is £2400 to give you an idea of the maximum retail price.
Any more details i'll try and stay active on the forum or drop us an email at:
[email protected]
www.selectmotorsport.co.uk
thank you.
Are you saying the rotors are aluminium or just the bells because I noted you described as hand anodised?
