Anyone experiencing their clutch pedal squeaking?
Blackthought_
Today the temperature dropped into the 50s here on the east coast. As I was pushing the clutch in, I noticed there was a faint squeak as it traveled inwards. Anyone else experience this yet? As the car warmed up, it started to get fainter but still there
Yes mine was doing exactly the same,seems to be coming from the engine compartment more than the pedal itself.
Update here -I applied some grease to the clutch spring and surrounding areas and after working it in a bit the squeak went away
Mine just started to do this. Where is the clutch spring and what grease did you use?
If you look above the pedals you’ll see it. You will have to be in an awkward spot lying on your back lol. Have lots of towels ready to soak up the overspray. It takes a little to for the grease to get in there you just need to use the clutch pedal a bit.
