Emira i4 - quickly overheating at 200+ kmph?
xanf
Hi! New i4 owner, unfortunately 1800+ km away from dealer.
While driving keeping speed at 200kmph very quickly (in less than a minute) constantly generates overheating warning with coolant temperature going from typical 90 to 110+ and very quickly back if I lift. (in a matter of seconds)
Is it expected behaviour? If no -what might be the wild guess here?
Nope, not at all, better go back to the dealer and have it checked
Sigh. Unfortunately due to my location this is close to impossible.
Will try to reach dealer via email at least
There were rumor's of heating issues with the I4T. These issue potentially caused the delay and got them back to the drawing board. But looks like not all of them were resolved. Hope you can get it worked out.
Yeah, my car is manufactured March 2024 (it was a long journey to have it delivered to dealership in Hungary and after that to Ukraine), I was hoping this batch had issues already resolved
Actually I've just plugged in simple OBD2 to gather some data and I'm confused
For example my dashboard says temp is 88 degree
OBD2 reports:
- coolant temp 79
- oil temp 95 (I thought i do not have oil temp sensor, however I read this about v6)
(is it a coincedence that (79+95) / 2 = 87, close to 88)
Will drive ane log some data here, because it feels super weird for me
I've recorded the stuff which confuses me even more. For some reason it refuses to embed - video is here
On the left side it is my dashboard. On the right my OBD2 sensors as reported by app - ECT (coolant), EOT (oil) and speed
The thing which I constantly see when "overheating" is an immediate jump from 90 to 106 and quickly increasing to 115 which can be seen at 00:29 and in the same way VERY quickly going back to 90 (matter of 10-20 extra seconds, unfortunately cut on the video)
I'm very confused because as you see dashboard behavior seems VERY different from OBD2 data
Status update: put a car at the service station, which quickly revealed that my entire bottom protection was full of coolant traces. After the check found a leak, with more than 5 litres of coolant leaked there in 3000km run
A bit disappointed to have this on a brand new car
Glad you got it checked out!
{more than 5 litres of coolant leaked]
Wow surprised - the car didn't overheat at lower speeds as well.
I am surprised it didn't blow your head gasket with that amount of fluid loss. At least it should be an easy fix and I am sure you will be checking the coolant level regularly moving forward.
Odd Emira's don't have a low coolant warning 'light/message'
