Emira Turbo (i4) Upgraded Exhaust Sound Clip
675430VME
Emira of the Month 🏆
May 6, 2024
472
740
Full exhaust system (Down-pipe without GPF, mid-pipe, and rear exhaust) with OBD active value control. No warning light.
Those shiftings are amazing!
What's the setup of the car to reach those 0-100 numbers?
How did you manage to disable the OPF/GPF on the ECU?
Mainly because of a pair of Recaro 2600A. A proper exhaust system will not trigger any warning light, so no need to disable anything on the ECU side.
TurboTambo - are you able to confirm the stock exhaust system only had a Single Cat no Secondary cat? thanks
Beautiful wrap on that car. Too bad there is no before and after Dyno.
