You are correct, a supercharger is driven from the crank, so it’s speed is constant and related directly to RPM. The turbo is not tethered to RPM directly, so can increase speed to compensate for altitude. In fact, early turbo designs were designed to be altitude compensators for piston aircraft.my basic understanding of the differences in the two is that the lack of oxygen will affect the supercharger, but not the turbo. but i don't doubt that I need to educate myself more. appreciate the direction that it is likely the difference would be nominal. thanks! i will likely go with the manual V6 in that scenario.
Cheers!
