"Engine Reduced Acceleration" error message
Jjrho
So, I just changed my oil at 950 miles n with car at 1010 miles and 3rd cat delete pipe n miltek valve ctrl installed, drove up the mountain, lake arrowhead. In so cal.... I did drive spirited....hitting redline a few times n hitting triple digits before corners, etc..
Any ways, the car suddenly shows the above message n the rpm gauge drops to 4k n I couldn't go any faster... the temp was 200 degrees n there was no other symptoms .... ambient temp was 101F ....
Went to the top of the month n stopped at a gas station n upon restart, still same issue, but since the car drove otherwise well , I went to the lake village and parked there and when I came back 3 hours later , the car started fine and RPM was allowed at full 6700... on the way down.... but the CEL was now on.... which I don't recall seeing on the way up ....I will read it tmrw n see what it says... if it's still On.....
What do you think guys ? Its like some limp mode or what ?!??
If this happens on a track day, it'd suck....
This car is fun but already too many "characters " ... 😆
I got this error message once, and it was on a hot day (mid 90s (F)) with slow traffic, so I attributed it to that.
It's weird because the coolant temp never went over 200 degrees, which is the usual temp I see when sitting in traffic, so it's not like the engine would've been hotter than usual.
Yah, it was over 100F but coolant was at 200F as normal....
Had the exact same issue happen to me last week, in Chicago traffic for well over an hour on super hot day. No CEL and everything cleared next time I drove the car. There are a number of people who have had this issue, some seem to be sensor related and others corelated to hot days:
