Added it to our site just now if needed again!@GRP since you're an Eventuri dealer, you should carry the filter cleaning kits too. I'd prefer to buy that from you if I can.
And they work well.Ours is a lightly oiled foam filter vs a woven media material type filter.
Don’t think Eventuri has ever made a carb eo intake. I don’t see them anywhere on CARB’s aftermarket list.Anyone here definitively know if the Eventuri intake is CARB compliant? I inquired with Galpin Auto Sports here in SoCal if they could help me install one and they couldn't under the assumption that it wasn't.
Yet when you look at the installation PDF, it does mention a CARB sticker:
The phrasing seems to imply that certification is pending. Has anyone who's installed received the appropriate sticker?
Thanks, just found the database. Welp time for me to move to an EPA stateDon’t think Eventuri has ever made a carb eo intake. I don’t see them anywhere on CARB’s aftermarket list.
Eventuri Intake Filter Servicing Kit
Eventuri recommends to clean your filter every 3500 miles. This can vary depending on the conditions the car is driven in but be sure to check it with every oil change. This kit includes the cleaner TO service your filter at least a couple of times. Oil included is not needed on Emira systemswww.gregsraceparts.com
Has anyone cleaned the Eventuri filter yet?
Nice. How’d you clean it? Simple enough?I cleaned a previous Eventuri filter at 5000 miles and the dirt that came off it was very minimal. This was normal road conditions and not a dusty dry area.
Why does the filter cleaning kit linked here require adding oil but the actual filter is a dry filter from factory?![]()
