Exterior color hex codee
RyanGphoto
Anyone know the magma red Seneca blue and yellow hex codes by chance?
What do you mean by hex codes? Those are usually for digital design.
Do you mean the PPG Paint Code that body shops use for repair?
No.. I meant Hex codes as I want to get some graphics done and they need the colors in HEX. Not sure if there is a conversion table anywhere... but thought I would ask here if anyone else did their car color in graphics.. I believe several have already gotten graphics done with certain colors..
I also wanted to paint the red starter lift gate yellow and they will need a paint code (which I now have from the other thread with paint codes), but I also need some graphics.
Ryan G
Ryan G
Can I get nerdy on you for a second? Hex codes only work universally digitally. Every printer is going to print the color differently depending on the ink.
Technically you’re looking for the CMYK color because that’s the 4 colors printers use.
The most accurate way to color match is to use a Pantone Color match - since it’s a universal color match tool.
Your best bet is to look at photos, grab a few colors, and do a few tests with the printer you’re going to be printing from
