What I like about this is that I think the I4 will feel faster most of the time and the v6 will feel more engaging more of the time. So instead of saying one is definitely better than the other, it's more a matter of preference/priorities.
It's unlikely the I4 has significantly different stiffness than the V6. Only the rear spring rates are different. The I4 has a different rear subframe so it probably just needed different pickup points and therefore motion ratios. The different rear springs are probably just what they needed to hit the same target wheel rates.
Go drive it again I have had 3 other Emira owner drove the i4 and without me hinting at the different spring rate. They all thought it's more bouncy compared to the V6 tour. both the front and rear spring are different from V6. I don't have pictures of mine but a friend with a i4 sport have taken picture of hisNot back to back, but I've driven both, and didn't notice any big difference. Significantly increasing rear spring rate only would also shift the balance much more toward oversteer. Lotus would have no reason to do this, just as they would have no reason to have a significantly different ride frequency target between the I4 and V6.
No offence, but I've worked with a lot of drivers and most will say they feel a difference between setups if they have an expectation of what that difference should be. Even if we changed nothing on the car, but said we did, most will say they feel exactly what we said we changed. Using blind changes is a big part of setup testing to remove expectations.
It's possible there is significantly stiffer rear wheel rates on the I4, but unless I see measured data showing this, I'm highly doubtful this is the case simply because it wouldn't make sense for Lotus to do that and the difference in spring rates is easily explained by the different subframes. It's not too hard to measure motion ratios if someone wants to do it when swapping out suspension parts so we can know for sure.
I believe this might be more than just spring rates. As a reminder, the weight split and detailed placement of weight, not to mention the overall reduction of weight, in the I4 vs. v6 is likely what is being felt. I can tell you unequivocally, the two cars, even though they are spec'd with the same suspension, feel materially different. The engine weight and placement alone are likely the biggest drivers.
Yea the numbleness definitely comes from the different front rear weight ratio, the i4 rotates faster/better.Any time you change weight distribution, and suspension geometry, you are going to feel it. Like you, I've driven both back to back in the same environment and they had different driving characteristics and feel. To me, the I4 was absolutely more nimble, felt lighter on its feet, and overall more balanced. Both were sport suspension cars. I'm simply commenting, because I think the "feeling" difference is more than just spring rate difference.
BTW, the fact that they had to change the spring rates tells you the suspension dynos and suspension sensors that they add for tuning were yielding very different handling characteristics when they were suspension tuning the I4s. no matter how hard they try, they will never be identical simply as a function of physics.
absolutely bob onWhat I like about this is that I think the I4 will feel faster most of the time and the v6 will feel more engaging more of the time. So instead of saying one is definitely better than the other, it's more a matter of preference/priorities.
