General Warning Triangle
GreggT
New here and still learning.......any help very much appreciated.
How can I tell what the 'General Warning Triangle' is trying to tell me?
Les than a 1,000 miles on the car but 170 of those would be to the closest dealer.
Any suggestions much appreciated.
You need a ODB II reader to read the code. Then someone here can probably tell you if it's something you can reset or is it serious enough you need to contact the dealer
Is it just the yellow triangle with an exclamation mark?
If so, using your right steering wheel buttons go to the tire pressure monitoring screen in the instrument cluster. Then press the right directional button twice and select “View”. It should show you information about the warning.
Mine has 500 miles and I have had that warning telling me something like right turn signal
twice and I shut car off and it reset ...
When I go into dealer for 1000 mile will mention it but with electronics today seems like norm
to reset no matter what we have ..
Thanks for trying to help....yes, it is the yellow "General Warning Triangle" and, clicking through the various fields in the monitoring screen I see " Service overdue" message.
Well at 900 miles, and, I did the 1st oil change last week, this is probably a system generated message and not an actual issue?....but wish I could be sure of that.
I'll look for a thread on resetting.
Thanks again.
Yeahs that’s why. You may not be due because of mileage but because of time. Does it say 0 days left?
There are instructions somehere in the forum on how to reset that service reminder
Edit: found this, pretty sure that’s what I did when I cleared mine.
That did it guy....thank you so much.
So...if were to guess it was a 'Service' reminder....and by the clock. 12 months since the car was turned on.
I bought it w/ 830 miles but know it was an early 2024 delivery.
'SOLVED' I think.
Back to breaking in this car. :)
Love it so far.
