GRP decat pipe and Milltek Valve Controller
BRM
New member
Queensland Australia
I'm about to install the 3rd cat delete pipe and I've seen that some people are also adding the Milltek Valve Controller.
Apart from the ability to open the valves without engaging Sport or Track modes, what's the advantage????
Nothing more than that.
Militek will allow you to full open the valve when you want. Something about how it does open after 4k in Tour, and maybe even in Track or Sport it still doesn't fully open??
I haven't seen any "logging" to show, but I skipped the militek because I didn't want to be bothered by the little remote, and if I want to change my exhaust behavior, I can do that with the factory modes.
Someone chime in to confirm, or call me out for being ignorant.
Yup, just allows you to control the valve. Also adds weight and introduces additional points of failure, however low the probability. Still, many consider the ability to control the valve far outweighs the cons. I have a set waiting to be installed next time I remove the diffuser.
It’s the best modification, I have the GRP, when installing the Milltek controller , PUT IT TO THE SIDE OF THE BUMPER. It will melt if left by the muffler
