High-Pitched whining noise steering
JP1
Hi everyone,
I’m experiencing an issue with my Lotus Emira and wanted to see if anyone else has encountered this or knows what might be causing it.
Whenever I turn the steering wheel, there’s a high-pitched whining or whistling noise that comes from the power steering system. It only happens when the wheel is being turned—if the steering is stationary, the noise disappears. It’s quite distinct and seems to occur as the pump is engaged under load.
To clarify, this is not the common "creaking sound" that some others have reported. This is a high-frequency sound that’s different in nature.
Has anyone else experienced this or have any insight into what might be causing it? Any advice or tips would be greatly appreciated!
Thanks in advance for your help!
It sounds like the steerin pump needs replacing. Others have had the same issue. I had a similar problem and Lotus noticed a leak from the pump at first service. It was eventually replaced under warranty. The noise will likely increase in the meantime. I hope this helps!
Hi
Thank you very much for your input!
Please see the attached video with the noise, is this also what you have experienced?
According to Lotus/the dealer this sound is fully normal.
Hi
That's not fully normal at all. Had that happen to past cars and it was one of the first signs steering pump failing.
Hi
Hi
Hej! This sounds similar to mine when the steering pump leak was identified at first service. Unfortunately the replacement pumps were on back order so the service guys said it would be ok to run the car in the meantime until the part arrived. I ran it for some weeks and the pump became noisier over time which the service guys said would happen but the pump did not fail totally prior to replacement. For peace of mind, I would get your dealership to check the pump for leaks as there were a batch of faulty pumps supplied so several owners have had these replaced under warranty. I hope this helps. Regards
Thanks!
I just informed them, but unfortunately, they simply dismissed it and claimed it’s supposed to sound like that. I’m very doubtful about this. Does anyone have a video/audio clip of a "flawless" car when making similar steering movements?
Same problem with my car, do you have any update on your situation ?
No updates beyond the fact that it seems the sound is coming from the pump. I’ve compared it with another car, and the corresponding sound is the same there. Therefore, I suspect “that’s just how the power steering pump sounds.” However, my dealer has promised to investigate further and consult with Lotus globally.
Have you spoken with your dealer?
Did you hear any response? I'm about to pick up an i4 tomorrow, and I heard a very similar noise a few days back and asked the dealership to fix it before delivery. Service personal responded with nothing is wrong, and we don't hear it anymore after lifting it - which I highly doubt.
I had this exact problem with my new i4.
The pump was diagnosed as faulty and is getting replaced at the dealer .
The dealer originally told me this is normal and is only heard in the AMG/i4 version. Apparently is has different power steering from the v6 - “it’s the same as McLaren use” as if that would help make the noise any less annoying.
Others I know with an i4 don’t have this noise, I’m going to approach the dealer again.
They’re not completely wrong. I4 has a electro-hydraulic steering and V6 has a hydraulic steering. I’m waiting to get my first 1000 miles in so I can get this fixed along with an oil change.
I have an i4 too and this sound is annoying if I’m not listening to music.
I’ve still to speak to the dealer, will do that first thing tomorrow.
I’ve also noticed it is particularly loud outside. The noise appears to be coming from the lower front of the bonnet.
The fluid reservoir/pump for the i4 is near the front wipers according to the manual. The v6 fluid reservoir is in the back.
I haven’t noticed the sound outside. Will check in a couple of days and update.
