How much will the i4 actually weigh?
Coilover
secure35
I have seen so many figures banded around as to the weight of the 4 cylinder model, most posted years ago without any concrete sources.
It's very tricky to discover exactly what they were weighing and under what circumstances.
Some manufacturer vehicle weights are 'wet weight', some 'dry weight' and some even include a nominal load for a driver and a piece of luggage(!) so it is difficult to compare like for like.
No one can/will give me a qualified answer as to the actual wet weight of an Emira.
Does anyone on here know?
  • #3
I’m aware that not even the press have them yet. I was more enquiring whether anyone had any concrete information from Lotus because at the FoS on Thursday they seemed a bit ‘vague’ to say the least.
I’ve had no further info since I was told the unoptioned Base i4 was 53kg lighter than the fully loaded First Edition V6, which was over a year ago. I believe Lotus usually publish EU DIN weights.
I am sure I saw something on the Lotus press release that said it was 12KG lighter.... in fact I did...
The introduction of the four-cylinder engine to the Emira range created the opportunity for Lotus to introduce a new, lightweight cast aluminium rear subframe to optimise the packaging of the powerplant within the chassis structure. It’s in place of the steel assembly used on the Emira V6 and contributes to a total weight saving of 12kg. The subframe also houses the new rear suspension.
Agreed.. the COG will be lower on the i4.. but I think a normal driver wouldn't notice that much
In order to compare apples to apples, and oranges to oranges; we will need to know the genuine weight of base model Emira (I4) and base model Emira V6, as well as Emira FE (I4) and Emira V6 FE.
I have a feeling that all the numbers have not yet been quoted and put together in an easy to read table⁉️
That’s right, my figures aren’t apples to apples and originated from info on the lightest and heaviest versions. The max weight difference is similar to a tank of fuel or a petite passenger. Most people won’t notice it.
Haven’t Lotus yet announced all of the 4 figures that I mentioned? Maybe official figures for the “base models” are lacking?
I believe that weight saving of 12kg was referring to the difference between the steel subframe assembly the V6 uses, and the aluminum subframe the i4 uses.
That’s right, no official Base Edition figures yet. Not expecting them until Q1 next year, along with other confirmed specs and options pricing.
1476KG, not sure how much gas is in the car but check this video out. They put the I4 NYO on the scales.
That's 3,255 lbs., only 12 lbs. lighter than the V6 with manual. I'm assuming that's with a full tank. One of our members weighed his V6 and it was 3,267 lbs. (1,481.9 kg). I was expecting the i4 to be about 50 lbs lighter.
That weight aligns closely with C&Ds weight. C&D weighs cars with full tank of gas @ 3,245
Roadholding, 300-ft Skidpad: 1.08 g for AMG
Found the V6 review-
C&D has the V6 @ 3,279
Also noticed something surprising in C&D test results - Roadholding, 300-ft Skidpad: 1.00 g thats a lot lower ... how can the cars be that different. Wonder if one sport and the is tour...
Has to be the difference in tires for the V6. The Cup2 would definitely out-perform the Goodyear.
