Infotainment HP / Torque survey (current stock record 423hp / 368 ft lbs)
275
195
Current record posted by member JackSlack ==> 423hp / Torque 499nM or ~368 ft-lbs. Outdoor Temp 45-50deg F.
750 miles left before I can toggle out of tour mode.....and take some runs for myself.
[Forget it, the infotainment hp meter is not accrue by any means]
Yes, values are all calculated with assumptions; however it's an interesting data point, and at the end of the day the data might not be too far off the mark .... plus its something interesting to evaluate ; that doesn't cost anything and is simple.
Have some fun ....
I've got a new exhaust and downpipe with sports cat, and the infotainment power meter still reads exactly 360hp under full acceleration. Never slightly below and never slightly over. Surely those mods would have at least give a few extra hp!!!! So basically the power meter is shite.
Your car is essentially factory detuned so It may be programmed to adjust parameters to never go over the 360.
[ adjust parameters to never go over the 360.]
Interesting postulation (think it lowers boost and timing accordingly to stay at 360HP ), thought I saw a post from a UK member who removed the primary cat. He stated he pickup HP on the infotainment display....(over 360hp).... think it was close to 400HP. Maybe he will see this thread and repost his metrics; might help
TurboTambo
YEs
TurboTambo
Yeah, I thought I'd see close to 400hp after the couple of mods. Hoping someone cracks the ECU code soon.
I'm surprised to see it go over 400bhp.
Surely it's not actually measuring the power, but just following a software algorithm (throttle position, RPM, gear values = X power)
If you modify the car, even substantially, I doubt these calculated values will change at all.
The just dropped a full spec M139 in the i4 in China and the US. There's been pictures and video showing stock China i4 with 419hp on the display from over a year ago.
