- Joined
- Mar 5, 2022
- Messages
- 2,623
- Reaction score
- 5,250
- Location
- Mountain View, CA
- Emira Status
- Emira Owner
Seems that Nitron have their hands on litchfield’s car! Excited to see what Nitron releases for the Emira.
I’m most excited for some mild 1” lowering springs to go with my sports suspension.
That sounds very interesting... got any links to info about the elec-tron system? Apparently I suck at googling today.Sounds like we can look forward to lowering springs, single adjustable, triple adjustable, and their newly announced elec-tron adjustable damper systems.
Unfortunately I don't, they announced them on November 11th, 2022 and showed them off at PRI in December at their booth, I asked them and they said they'd have literature on it "soon". They call them "semi-active" dampers -- so I'm guessing they're just electronically adjustable dampers and not an active system like you'd find with Tractive where it has a central compute unit with acceleration sensors.That sounds very interesting... got any links to info about the elec-tron system? Apparently I suck at googling today.
Nah, their elec-tron system is likely a monotube damper with a single electronically actuated spool valve. Comparable to say the Bilstein Damptronic systems. The R3 would be a manually adjustable system with height, compression, and rebound adjustment.Probably be an Emira tuned version of these:
Nitron NTR R3 Suspension Kit | Litchfield Motors
www.litchfieldmotors.com
I don't think I'd be able to justify forking out for expensive continuously-variable magics... but just being able to flip between 2 or 3 damper settings for different situations without getting under the car and fiddling with knobs would be pretty damn slick. I will be keeping an eye out for this, for when the modifications bug bitesUnfortunately I don't, they announced them on November 11th, 2022 and showed them off at PRI in December at their booth, I asked them and they said they'd have literature on it "soon". They call them "semi-active" dampers -- so I'm guessing they're just electronically adjustable dampers and not an active system like you'd find with Tractive where it has a central compute unit with acceleration sensors.
my wallet: ouchAgreed!
If it were continuously variable like a Tractive setup, you'd expect similar or competitive pricing.
Back in 2020 I inquired with DSC Sport directly and you could expect the following:
$1,500 for the DSC controller
$6,200 for the Tractive Road and Track dampers, Swift springs, and upper/lower perches
YikesProbably be an Emira tuned version of these:
Yikes
£3,736.50 exc VAT
£4,483.80 inc VAT
plus install DAMN
I believe it. If I bought a 718, I’d drive straight to new German for some OHLINS. But electronically controlled witchcraft is too much money now and when they fail for meI think Nitron actually offers some incredible performance for the money compared to other motorsport dampers.
