Dmitrii_MOCKBA
New member
- Mar 9, 2025
- 1
- 0
where can i buy an OBD cable to connect my Emira (3,5l) to a laptop for diagnostics and clearing errors? please specify the specific model and manufacturer of the cable.
From China maybe? No sanctions there.How did a Lotus get to Moscow?
Would you mind sharing your experience with EmiraDS platform? I am curious if one is able to perform module updates through EmiraDS or calibrations?A generic OBDII interface device will only get you the generic codes. In order to use the Lotus diagnostic software specific for the car, EmiraDS, you need to use an SAE J2534 Pass Through Device with DoIP (Diagnostics over Internet Protocol) to connect a Windows computer to the OBDII port. Lotus recommends the somewhat pricey "Mongoose Plus MFC3-BT". I bought one but I'm waiting for the rugged Windows tablet that I also ordered for it. I fail to understand why manufacturers have not implemented OBDII diagnostics on the built-in infotainment interfaces. Imagine how helpful that would be.
I hope to as soon as I have the complete hardware set up. I'm going to push most at verifying firmware versions and updates.Would you mind sharing your experience with EmiraDS platform? I am curious if one is able to perform module updates through EmiraDS or calibrations?
"Important: The Device That You Use to Purchase a Subscription Will Be the Only Device That You Can Use to View Technical Information or Access a Diagnostic Platform"
