Rear Diffuser Rear U Clip Replacement
itsnightime
7
0
Anyone know the part # or where i can find a replacement part for the U clips that holds the rear diffusser panel right behind the rear wheels? Tried buying some from Amazon, but none seems to fit.
Thanks for the help
I found two of them on the floor when I removed the defuser to add 3rd cat delete pipe. Can’t figure where they go????
I had the same thing happen when I did mine and almost just threw them away but found out where they go. If you look at @itsnightime s attached photo in the first post, there is a small notch in the bottom of the rear wheel well behind the tire where the diffusser meets the lower body panel. The clip fits in there to clip the diffusser and lower lip body panel together. I hope this explanation makes sense,
