Gosh this just about mirrored my test drive thoughts. Particularly:Had my test drive at Rybrook Bristol today. Nimbus with red leather on touring suspension. The test route offered wasn't that great but I managed to skip the motorway sections and take a couple of local B roads instead which improved things.
The car still looks lovely on the outside, even the dirt spatter pattern resulting from the damp and mucky roads complements the shape nicely. The interior is ok but overly minimal, particularly with the leather which made it all seem a bit clinical - note that I have spec'd alcantara as I like the tactile aspect it brings. It all seemed to be nicely put together but sits in a bit of a no mans land between the sparse but purposefulness of an Exige interior and the functional but sporty elegance of a 911 and as such seemed to lack a bit of character. I felt the seat was a bit high and felt like I was sitting on rather than in it when I first got in, but I realised now I didn't think about them again after that and I am normally a constant shuffler as I try to find the perfect position.
The car only had 100 miles on it so obviously not run in at all, although I wasn't asked to keep the revs low so put it straight to sport mode and took the opportunity to stretch it as and when the roads allowed. The engine & exhaust noise was good but a little muted, I guess it may get a bit louder as more miles are added. You can hear the supercharger doing its stuff and the burbles as you lift didn't seem overly in your face although are ever present. At low speeds a gravelly sound from the transmission dominates which I assume is the bearing noise referenced from the Evora by others which is less nice.
At low speeds it isn't too bad over your standard British B road imperfections but you do know it is a sport car. However as you gather pace things smooth out and you are mostly just aware of the undulations and broken surfaces as opposed to feeling them. The touring chassis seemed a great match for the roads I was driving on staying flat and composed where others (M, Cayman, Boxster) have struggled even in 'comfort' mode. On the damp roads the traction was impeccable and the car was willing to go where ever I pointed it. It clearly had a lot more in it than I was trying to extract. It might not the fastest thing out there but it did feel fun and alive at public road speeds which is good for the driving license.
Other things:
- The steering wheel (leather) feels really nice in the hands when threading the car down the road but I'd rather something round when manoeuvring.
- As noted already there is a reliance on menu diving to set or change anything and the display is very minimal. I was going to say function over form but I found I really had to look to work out how to do anything
- The touch sensitive action of the steering wheel buttons was a bit annoying as I kept swiping by mistake, but if you can turn that off they will be fine and even if you can't I suspect you would quickly get used to them.
- There seemed to be some wind noise coming from the rear of the drivers window when closed, I checked because I though I had left it open a crack.
- When checking out 'that' seal I noticed the front boot seemed to misaligned, lower on one side than the other.
Gearbox
Wind noise
Backache
Engine (strangulation)
And your Evora ownership etc mirrored mine, so we no the foibles
Other issue was I thought centre iPad screen angle was wrong for driver. Didn’t like it.
Very interesting and needs a thoughtful consideration what previous Lotus owners are expecting. Maybe we aren’t it’s market target.
