I’m having a little work done on my Emira’s suspension. Does anyone have the torque specs for the various fittings?
I’ve got the I4. I downloaded the V6 service manual (after I posted) it seems there isn’t an I4 version available yet. I used the V6 specs, the stuff we had to remove looked identical, so used those specs. Was only removing the shocks.Do you have the V6 or the I4 Emira?
I ask because I have information for the v6 only, some mounting points for the i4 suspension are completely different than the v6 and may have different torque values.
We later removed the front callipers to skim the discs, the manual states the 2 bolts holding the calliper should be replaced if removed. Is that really necessary, or maybe that’s a bit overkill?
Yeah I figured that it’s not essential. It’s not so much the cost, but rather the hassle of sourcing the parts.A large number of the bolts are identified as renew. I think it’s a precaution, it doesn’t hurt, but it costs more. In my head, as long as it’s not torqued to yield then it’s most likely fine to re-use.
