Why won’t the bloody thing start?!
Andjons
This is really frustrating. Everything was fine for about a month. Now, the car won’t start when I first try to start it. It does eventually, but there is no pattern to it. I unlock and get in as normal. The scorpion tracker unlocks (this is confirmed on the phone app) and I wait a few seconds. I press the brake (it’s an auto) and the start button. I hear a sort of hiss noise from the engine bay for about 2 seconds (like something is pressurising) but nothing happens. I turn off the ignition, and turn it on again. I lock and unlock the doors again, and go through this routine several times. I am pressing the brake nice and hard, and I am pressing the starter for varying lengths of time. Eventually, maybe after even a few minutes, it will start. But there is no apparent reason for the reluctance, and the bloody annoying wait. There is only one error code on the OBD2 - something surely unrelated, about the ABS. It is really starting to piss me off. Any thoughts?!
My 2 cents and that is all it is. I use to have this issue on my V6 M when pressing the brake to start, since then I only press the clutch to start and never had a problem. I think it is a sync issue between the brake and start system. Again, my 2 cents.
Battery? Check to make sure the cables are securely attached to the battery posts. Have the dealer do a battery health check; make sure it's charging properly and holding a charge. Could be an improper ground connection somewhere. Check the ECU (Lotus calls it the ECM) connection to the engine (which is the ground connection for the ECM). It's the orange-colored bolt in the middle of this diagram. Check to see if it's secure, and clean. If it doesn't look right, remove the bolt, clean it and the contact surfaces of the cable end and the engine, then re-install. They don't list the torque spec in the manual, but for an M6x12 I'd guess 10nm.
It’s annoying but if you get out of the car lock and unlock it will start. My dealer was able to solve it on my previous car
If only the Emira had true ECM. :D
Todd from Everyday Driver had a non-starting issue during his recent road trip. Sounds like a different issue than the one Andjons was experiencing, but Todd's seemed to resolve itself after sitting for a while. Disconcerting, but glad he was able to continue his trip!
The dealership in SF did a couple of software updates for him, so maybe that'll prevent further issues...
Have had zero problems with my Sept 23 V6 manual until last weekend when without warning, it just wouldn’t start - just like Andjons, all I could hear was the hiss sound from the fuel pump, but nothing more.
Called Lotus Silverstone who took me through the lock/unlock routine but all to no avail and after checking they said there is a newer 20 mins software update (since my last one in Dec 24) which should rectify the problem.
Called Lotus Assist who sent out an AA engineer (despite me telling them that he wouldn’t be able to start the car and to go straight for a trailer) and guess what …. 4 hours later and having checked the condition of the battery and all groundings etc., he admits he can’t start the car and requests a trailer.
Two hours later, the trailer arrives and as the parking brake can’t be released, he has to use the winch to physically drag her up onto the bed of the trailer … it’s a sound you never want to hear !!
30 mins later we arrive at Silverstone and as the AA guy unstraps the car, the engineer jumps in and unbelievably, the damn thing starts up first time !!… we were both left speechless and felt like complete idiots.
It really makes no sense at all but I guess you just have to put this down as yet another strange quirk of owning one of these cars 😩
Obviously, the update was then run and a huge thank you to Graham Kempton @ Lotus Silverstone for the immediate response and fantastic customer service and let’s just hope that it cures the problem and we don’t get any other issues arising as a result.
Wait until android auto or carplay loads on the center screen then start. That's the only thing that consistently works for me or else it is hit or miss
@TonyV6-UK
Got my car back today after an AA call out and then a wait for a trailer trip back to the dealer on Friday. Faults cleared back at the dealer on unload too but now I’m sat stranded on my driveway a second time in 3 days because the car now won’t start. Different issue now. Unlocks fine, but says no key in the car. Less than two weeks since delivery and I’m starting to regret my decision already! Batteries replaced in the fob. Done a battery reboot in the car and still no luck. Do you recall the unlock/lock procedure you were given? I need to move the car 🤦‍♂️
@TonyV6-UK
Have you tried putting the key in the keyfob shaped bit under the armrest at the bottom?
Yes. Tried everything now. Both keys, new batteries all round. Tried under the armrest, tried in the cupholder, i disconnected the car battery, I’ve tried unlock/lock sequences, clutch pedal cycles, same with brake, seatbelt on/off, all in all about an hour of trial and error and nothing.
I’m really in two minds right now about accepting that there is a reason the car was sold so early by the previous owner and getting out while I still can, OR accepting it’s part of the “lotus experience” and letting the dealer try to sort. I love the car, but not sure I can put up with this sort of hassle every few days.
Since it’s an earlier build, I wonder if it was ever fitted with the water ingress shroud to the front fuse box. Possible you have corrosion or fried fuses?
I had a look this morning - quite a faff. There is a rubber shroud in place. It looks like water has been pooling on the top though. I’m also not sure how it’s supposed to drain correctly but mine looks like it channels towards the cabin and to centre of the bay.
