Window issues
MapleOreo
Active member
Had a weird thing happen when I got home.
Parked in the garage, tried to put the drivers window up before shutting it down and exiting.
However, each time I hit the button, the window went all the way up, then immediately went down half way.
It did it about 15 times.
I eventually tickled the switch enough to get it closed.
However, because I didn't want it to go down again, I may have stopped a quarter inch from it being fully closed. But I'm not sure. This is a long-winded way of asking, has anyone else experienced this problem?
I once had something similar… Just held the button up and kept it pressed for a while even after it went up. Then held I’d down and kept it down for a while and it sorted itself out.
Oh man I hope it’s not the problems that the Evora faced with the window regulator. That regulator went out in earlier evoras and was costly to find that regulator. When I had my Evora I had the same thing. Window would have a mind of its own until it finally gave out. Worst case scenario is it gives out as it’s raining!
