šŸ““ Journals 19 Months 12 Days later
Just going to disagree with myself here.
Been for a drive and the belt sits awkwardly on the shoulder.
Must have had the wrong shoulder on yesterday.
I’ll be straightening out the twist tomorrow.
I tried that on the demo here in Bilbao, only to find out that then it will be twisted in the bottom, which is much worse.
Needs to be untwisted by dismantling the belt down by the seat; I guess better let the dealer do it.
Pretty simple fix, if you do choose to tackle it.
Reactions: KJD
Tried on some luggage.
2, ā€œeasyJet specā€, full size carry-on cases. 53x40x23cm.
Perfect fit. Seat slightly forward of fully back.
10kg each, of course.šŸ˜‰
Room for some soft bags on top, and that’s without even starting in the boot.
Which will take one case and plenty of soft bags.
It’s a van.
2, ā€œeasyJet specā€, full size carry-on cases. 55x45x25cm.
It’s a van.
Great to finally see this photo...thanks KJD...now I just need to see three of the same bags put in vertically (of each less than 7kg of course)...and if anyone would like to try to squeeze in a slightly german shepherd and border collie (not at the same time as the bags of course) without incurring the wrath of the RSPCA then I can happily tell if she fulfils all my reasonable GT requirements.
I’ll have a go tomorrow in daylight for you.
Might struggle with the dog bit though.
I don’t think 3 will fit. It’s about 110cm wide. So 2x 45cm leaves 20cm.
edit:
Just measured those cases and they’re actually 53x40x23.
Still won’t fit 3 in.
What's that bit loose in the cowl tray, just in front of the wiper arm?
It’s a van.
Yesterday I was seriously wondering if I could put my medium size cavapoo behind the seats. Put a soft dog bed behind there or something. 😁
One of the little covers you have to pry off to get at the panel fixing screws.
You can just see another one top left.
They’re captive, with a little plastic lanyard.
Unlike the bolt, which looks like it’s not a captive one?
