2nd check engine light in less than 500 miles
BlueEmira6mt
Hi,
I posted a few weeks ago after getting my first check engine light with about 300 miles on the car. That code was p1302. Also got “Engine reduced acceleration” warning on display.
That all went away the next day.
Last week, I dropped off my car for full PPF and ceramic coating.
Two hours after I dropped it off, I get a phone call from them after having the car washed.
They said upon starting the car they got a low oil level warning and check engine light.
They checked the oil level and that was fine.
They checked the code and it was P223D.
Something to do with the o2 sensor.
When I got my car back this week, the check engine light was still on. I cleared it today, drove it 15 minutes without any problems. After restarting the car a few hours later the check engine light came back again.
The car has less than 500 miles.
Any ideas what can cause code P223D? Again this happened right after the car was thoroughly washed.
Should I stop driving it?
Will call the dealer on Monday but wanted to see if anyone had any insights on this?
Thanks
Could be water in the front fuse box/loom. Apparently there’s a seal that wasn’t/needs to be installed. Apparently water off the windscreen runs down, through the vents at the top of the bonnet (hood) and seeps into the fuse box. It’s a large dealer repair if that’s the case.
Yea. My guess is pressure washer got something wet.
I think you are right about the water. I have a feeling that it might have burned out the o2 sensor. I erased the code twice. The cel doesn’t come on after initial drive but on the second start it comes back.
That's right, there is a recall due to water seepage into some connector box. Your dealer will then install a flexible plastic membrane that prevents water from seeping through to this connector box.
Of course, I cannot say with 100% certainty that this is the cause of these specific error messages. For me it was a combination of EVAP error messages, they also had to replace a part for this, although under warranty. The problems with the membrane mainly caused problems in the air conditioning and ventilation.
This makes sense.
However, my car was built about 4 months ago. Why has this problem not been fixed already? These cars have been out for a couple of years. I can understand if it's the first year but this should not be an issue by now.
Anyway, I'll be headed to the dealer this week.
This makes sense.
After a certain VIN number the EVAP water shields were added from the factory. Given yours was built recently it should have had it installed then.
It was supposed to be a short term fix until they designed the components to be more water resistant. May not be your issue as it primarily affected the AC blowing cold or the fan not running.
Its possible something in the rear got wet or just another Lotus quirk to chase.
I think there’s two issues here. I don’t know if the ‘HeVAC shroud’ also covers the front fuse box or if that’s another, separate shroud, but there are definatly two separate issues created by water ingress from the front windscreen. My car had no issues at all with the HeVAC system, but error messages for the front lights, horn and safety restraint system. The garage said these error messages were caused by water ingress into the front fuse box/wiring loom.
Could be unrelated, but when I first got my car, I was getting check engine lights off and on for about the first 1000 miles. I think it was the battery after sitting in shipping/storage, because I have not seen it since and have been driving the car at least weekly to keep the battery charged.
However, my car was built about 4 months ago..
Just out of curiosity, V6 or i4? Not that is makes a difference. But, I'm picking mine up next week, and this is the type of situation I am dreading.. Like you I would have thought we would have been past these issues..
The Emira is sensitive to battery charge level. If the Lotus supplied battery charger/tender is included with your car (it should be), it's not a bad idea to put the car on the charger when you get it, and let it fully charge.
A week after getting the car i had a check engine light, i was out of town and the car was unplugged. I experienced a low-voltage issue. Since then, I’ve kept it plugged in consistently and has never come back. Some of the challenges you faced were similar to mine after connecting to the OBD port.
Update:
I dropped my car off last Thursday and picked it up today (8 days at the dealer).
Dealer called me last Thursday afternoon saying he had never seen that code or message before (code P223d). Contacted Lotus for support. They instructed him to replace O2 sensor.
He said there are no recalls on my car (built September 2024).
I asked him why would washing the car cause this problem and if it can happen again? He said he’s not sure why it happened but doesn’t think it’s going to happen anymore. We will see.
The weather is cold and crappy here in NJ but boy did I miss driving this car. I love it! Can’t wait for better days and to finish breaking it in. Almost there!
I’ve had 2x o2 sensors replaced. Last time the dealer mentioned something about cars that were getting moved small distances in places like detailers had problems. I don’t understand how this could be the case. Maybe unburnt fuel in the exhaust landing on the sensor is not being blow dryed by exhaust gasses on short startups. Also wondering if sport/track mode overrun pops are causing this due to fuel in the exhaust system?
This is interesting, mine is an August 2023 delivery (V6) car, I have had the check engine light come on a couple of times, once a couple of months ago and again last weekend. My car is kept on charge but both times it coincided with the car being washed and only driven short distances, the last time I then left it without putting it on charge over night.
I contacted Lotus in Lewes and although they are a sales only department the manager suggested that I take the car out for a long run, today I did that as I had an apppointment 40 miles away, went to the appointment and when I left again, hey presto - no check engine light!
I've had the HVac shroud installed but find that my Aircon blower is quite is quite loud and 'whistley' although it does work OK, so I wonder if it's still a problem. I also remember reading somewhere that there is a second battery in the Emira that only gets charged when the car is actually being driven (not on trickle charge) and the check engine light could be triggered by low voltage in that battery, that would explain my problems and the fact that it seems to be solved by a longer drive.
2nd Update:
On Jan. 24th I had posted an update, I had just picked up the car after the dealer replaced the O2 sensor after check engine light (code 223d). This was probably caused by the detailer washing the car. The code had appeared right after it was washed.
The next day, Jan 25th, after driving about 30 miles on the car the check engine light came back on. Code 223d reappeared.
In addition, code P219B (bank 2 air fuel ratio imbalance) and P2273 (o2 sensor signal stuck rich) also come on for the first time. Car still drove fine but was idling a little rough (dealer also confirmed this).
Dropped off the car on Feb. 4th and finally picked it up yesterday March 11th. It was at the dealer for over a month!
The dealer, with help from Lotus engineers in the UK, decided to replace the main computer module (ECU).
After new ECU, the CEL come back on.
Sales adviser said that they were lost at this point and waiting for UK engineers for guidance.
They advised to replace both upper O2 sensors instead of just one.
I got the call that the car was ready for pickup yesterday March 11th. More than 35 days later.
Drove about 50 miles so far and all seems fine for now...
Reactions: SJM
I had my o2 sensors and cats replaced for CELs to at I was getting for o2 sensors when I first got my car. The o2 sensors are Chinese junk!!
I think the 2nd battery comments are related to the telemetrics warning.
Reread this and noticed this. I didnt think there was a low oil warning light on the V6 (should be one). I know the AMG has a elec dipstick so should have one..edit: it comes up as a message warning on the AMG.
The manual says there is only a low oil pressure warning but no level warning. (v6)
Anyone know for sure if there is a oil level light on the V6?
