AC temp control is useless (always cold no matter what)
Cwolf
North Carolina
Anyone have the same problem? You can have the temp control on 62 degrees or 76 degrees and it still just blows very cold. I am not talking about the AC fan issue which was a failed resister. I had that replaced and still not 100%. I am talking about the temperature and how no matter what your set it on for AC, it is just cold.
Anyone else experience that?
I have to pay closer attention. The AC does run cold though. I’m often actually turning it on or off around 72. I never really run it at 6x so not sure if it gets even colder.
I am facing this issue now, but always run hot. The AC has some flaps that regulate flow/temperature and in my case, they need to be replaced for the AC to function properly. This might be your issue too, test if all the vents blow evenly, because some of my vents are not blowing at all.
