FlashingBlade
Thanks, I'll give them a call on Monday. Now I've got over the 1000 mile break in I'm not too fussed about someone coming to pick it up and no doubt thrash it back to the dealer
Same problem for me. Seems a common fault. I’ve had my car 11 months and it started about a couple of weeks ago. One thing after another with the recalls. It’s getting serviced soon so I will line it all up to be done at the same time.I'm having a problem with my aircon, does this sound related?
With mine, my fan/air con isnt coming on reliably. Take this morning, got in the car and after driving about 50 yards it started to mist up, okay, turn on the demist button - nothing. Turn the blowers up maximum manually using the rotary dial - nothing.
I pulled over and wiped a portal in the windscreen so that I could see and carried on and then after about five minutes of driving, the fans kicked in. It happened like this twice today. I need the fans/demist to work from the minute I get in the car, not ten minutes down the road.
It's been replaced. Everything works now and what can I say... it never worked before as it should've. If your aircon "kinda blows strong" on max, it's not fully working. If I turn mine to max now it sounds like there's a jet engine on board.I'm going in on the 14th, complete big heating "box" under the hood to be replaced
Exactly my scenario. Lotus should be aware on how to fix this.Same problem for me. Seems a common fault. I’ve had my car 11 months and it started about a couple of weeks ago. One thing after another with the recalls. It’s getting serviced soon so I will line it all up to be done at the same time.
It's been fixed again. Now it was the resistor - full of water!It's getting ridiculous. Car made it to the first rain, now aircon isn't working again. Back to square one -_-
Mine too is now sorted, B&C replaced the resister pack with a new sealed one + additional dealer sealing where it meets the loom (think thats what the service manager said)
I also had new wiper motor and a new raft of software updates after only having them done last month there is more come through apparently,
Only had the car a day pretty much as they have done so many now it takes them about 5hrs as opposed to the 9+hr plus its supposed too.
Have asked for a courtesy car and have been advised that a fee is chargeable for a courtesy car from 1st Jan.
If possible, Lotus Cars will organize a replacement vehicle to continue your journey with a maximum of 5 business days.
I am waiting for an appointment since August.To be fair the Roast side assistance states
However, having to wait till January for an appointment stinks
Is this the shop where you bought it? In that case, you should've set a timeframe for them to fix (do it now, you need the legal grounds) and push for withdrawal otherwise. If you follow through or not, that should set priorities in order. Keywords to search for: Sachmängelhaftung / Angemessene Nachfrist. Hint: Since it's cold outside and your window could fog up unexpectedly this is a safety issue - a "erheblicher Mangel" - which risks "Verkehrssicherheit und Betriebsbereitschaft"I am waiting for an appointment since August.
I do not want to go the tough legal road yet for several reasons.Is this the shop where you bought it? In that case, you should've set a timeframe for them to fix (do it now, you need the legal grounds) and push for withdrawal otherwise. If you follow through or not, that should set priorities in order. Keywords to search for: Sachmängelhaftung / Angemessene Nachfrist. Hint: Since it's cold outside and your window could fog up unexpectedly this is a safety issue - a "erheblicher Mangel" - which risks "Verkehrssicherheit und Betriebsbereitschaft"![]()
Strattons are doing mine now (same issue, built around the same time) so they will have had some practice already - I believe it's quoted at 9 hours and the service notes show virtually a full front-end strip down to reach the fan resistor part that lets water in.....HVAC on mine (July 23 build) has been "interesting" from the start. As my initial miles were with AC on for cooling, and it worked reasonably well, I thought there was no problem. But first time out in the cold and rain, I had to have max demist on with AC to stop the windows misting up. Switch AC off, and they misted up quickly. Never had this problem with any other car. Fan has never seemed to be very powerful, even at max setting, although once it did sound a bit rough.
Today I went out in the rain and there was no heater fan at all, which made life a bit, how would you say, "tricky"? Waiting for return call to book in for repair with Stratton Motor Company. I really appreciate this forum, and in particular those posting on it, for sharing their experiences.
I absolutely love the car though, and the reaction of others to it - so very positive (so far!), everyone seems to love it. Magma Red 1st Edn V6 manual, Silver Wheels, Red Calipers, privacy glass. Closest I could get to my ideal spec on the cancelled orders list, reduced my wait down to a week.
