Knowing Lotus, if you only asked about the shroud, they will only respond about the shroud. I would suggest asking about both the shroud and the sealing of the fuse box. Otherwise you may not get all the info you need
If you keep the car locked and disconnect the battery, when you reconnect the alarm will sound no? It does for me. Boy is that alarm piercingly loudLocked the car this morning - thought I'd see if the alarm would go off before trying to disconnect the battery......
No trigger.... tried a couple of times, no problem, back to normal.
I've emailed Lotus regarding the issue, and when it's not raining I'll look to see if the shroud has been fitted (I've also asked Lotus if they know, presumably they keep a record...)
Will report back if I learn anything new.
Possibly, I was going to do it with the car unlocked. The alarm is incredibly loud, I had to go grab some ear plugs when I was trying to get it to stop!If you keep the car locked and disconnect the battery, when you reconnect the alarm will sound no? It does for me. Boy is that alarm piercingly loud
Was it after washing too?I had this issue twice in the same day. I unlocked and opened both doors and the boot and shut them solidly. Cleared up and never returned.
