Annoying Rattling Noise When Car is Warm
Does anyone know what kind of clutch type is on the Emira, ie sprung or unsprung/non dampaned? Also, i'm assuming the manual has a single mass flywheel. Wondering if these components may contribute to the gear chatter.
It's a sprung type clutch and lightweight flywheel made by AP (or was it ACT?)... Pretty sure a Lotus tech told me it was AP (same as our calipers). @Porter may be able to confirm... 🤔
Not sure if this is helpful:
Generally speaking I think a lot of the driveline noise that people experience on these cars is a result of it being a relatively sporty clutch combined with a lightweight flywheel. The sounds that the Emira makes are not dissimilar from other cars I've had (or worked on) that had lightweight flywheels.
The solution in my own Emira is to simply drive it in a higher RPM band than I would normally use in a standard vehicle, because the noise disappears above about 1500rpm.
I generally don't ever let the RPMs drop below 1500, and I accelerate for a longer period in each gear even when driving slowly, to keep the revs up after they drop on the gear change.
To editorialize slightly... I suspect that automatic transmissions in normal daily-driver cars have given many of us an "auditory memory" for shifting that's much lower in the rev band than appropriate for this car, so we have to un-learn it to have a good experience with this car when driving at sedate speeds.
Now if you're doing this, and still experiencing a rattling noise that's unaffected by the change, then something else is going on and you should have the dealer investigate.
i think in some cases, the chattering noise if from the lightweight flywheel. If you do a generic search for lightweigh flywheels pros/cons chattering noise is at the top of the list.
I think what youre describing is normal for lotus cars. On the Evora GT I had it sounded like marbles in a tin can when I accelerated slowly. I hear it I common for the Toyota transmission that is used in these cars
I went from a 22lb flywheel to a 8lb flywheel in my S2000. Love the performance but got intermittent drivetrain chatter upon deceleration. It sounds a lot like the noise my Emira makes while “lugging” the engine.
How much does the Emira flywheel weigh?
Hard to tell how quickly it revs with drive by wire and various driving modes :/
Hi, do you have an update on this? I picked up my Emira yesterday and I think I have your issue. It sounds way too loud to be a standard thing they all do. On mine it’s noticeable in 2nd, 3rd and 4th from 1000rpm to just over 2000rpm. Above 2200 it disappears completely. Is that the same?
By the way, I’m in south Hertfordshire if you want to meet up and compare?
Whereabouts in south Herts . I’m based there too
Stop driving the car at such low RPM. You're lugging the engine. Keep the revs above 2k unless you're starting from a stop.
Yes, this will probably mean you use a lower gear than you are accustomed to. Maybe even 1st for long periods when driving at low speed.
From a standing start you have to go through that rev range, unless you over-rev it and slip the clutch like a learner
So the noise wasn’t “what they all do” as the car, with less than 800 miles on it, is now on a low loader on its way to have a new clutch put in it!
Mine is now 15 months old, has done 9k miles and has had its first service at Lotus Silvertone… and it’s still makes the exact same sound you’re describing - it’s done it since the day I got it from Hethel. I keep being told it’s normal and nothing to be concerned about but agree with you it sounds odd. I’ve not got used to it. I’m based in Herts too, so happy to meet up and compare if you like?
I’d be happy to meet up. Only problem is, mine is now in the dealer as the clutch collapsed! At this stage I don’t know if the noise was part of the problem.
