Does anyone know what kind of clutch type is on the Emira, ie sprung or unsprung/non dampaned? Also, i'm assuming the manual has a single mass flywheel. Wondering if these components may contribute to the gear chatter.
Whereabouts in south Herts . I’m based there tooHi, do you have an update on this? I picked up my Emira yesterday and I think I have your issue. It sounds way too loud to be a standard thing they all do. On mine it’s noticeable in 2nd, 3rd and 4th from 1000rpm to just over 2000rpm. Above 2200 it disappears completely. Is that the same?
By the way, I’m in south Hertfordshire if you want to meet
Waltham CrossWhereabouts in south Herts . I’m based there too
Stop driving the car at such low RPM. You're lugging the engine. Keep the revs above 2k unless you're starting from a stop.Hi, do you have an update on this? I picked up my Emira yesterday and I think I have your issue. It sounds way too loud to be a standard thing they all do. On mine it’s noticeable in 2nd, 3rd and 4th from 1000rpm to just over 2000rpm. Above 2200 it disappears completely. Is that the same?
By the way, I’m in south Hertfordshire if you want to meet up and compare?
Mine is now 15 months old, has done 9k miles and has had its first service at Lotus Silvertone… and it’s still makes the exact same sound you’re describing - it’s done it since the day I got it from Hethel. I keep being told it’s normal and nothing to be concerned about but agree with you it sounds odd. I’ve not got used to it. I’m based in Herts too, so happy to meet up and compare if you like?So the noise wasn’t “what they all do” as the car, with less than 800 miles on it, is now on a low loader on its way to have a new clutch put in it!
I’d be happy to meet up. Only problem is, mine is now in the dealer as the clutch collapsed! At this stage I don’t know if the noise was part of the problem.Mine is now 15 months old, has done 9k miles and has had its first service at Lotus Silvertone… and it’s still makes the exact same sound you’re describing - it’s done it since the day I got it from Hethel. I keep being told it’s normal and nothing to be concerned about but agree with you it sounds odd. I’ve not got used to it. I’m based in Herts too, so happy to meet up and compare if you like?
Oh! Well give me a message when it’s back - maybe it’ll be a bit better!I’d be happy to meet up. Only problem is, mine is now in the dealer as the clutch collapsed! At this stage I don’t know if the noise was part of the problem.
Once I get it back, I’ll let you know if the noise is still there or whether it was related to the clutch.Oh! Well give me a message when it’s back - maybe it’ll be a bit better!
What went away was the clutch thrust bearing lol!it took the clutch plates and the flywheel with it when it went!No worry, it happens in winter. When the temp is higher, it goes away.
