Does anyone else have the problem of hot air randomly blowing out the climate system when set to Auto? I tried to have this serviced in DC with no luck.
I’ve wondered about this because a lot more air comes out from my central vents verses side vents. They work but it is noticeably weaker.Same here, I am scheduled for a repair next month, my dealer suspects it is some issue with the AC flaps that regulate air temperature/flow, because some of my vents are not even blowing air, you can check that too. WIll keep you updated.
Yep, should be the same thing I am experiencing, the flaps in my AC malfunctioned (maybe due to moisture from cleaning the car?) I got some moisture shield on the AC installed under warranty and now I am waiting to get the AC flow system replaced in 2 weeks.I’ve wondered about this because a lot more air comes out from my central vents verses side vents. They work but it is noticeably weaker.
Thats the HVAC recall from Lotus, we all been thru that failure.. if not it will come sooner than later.When my climate is set to auto is nearly always blows cold air out the windscreen vent no matter what the temp is set to
:-(( I thought the fault was about the air randomly blowing hot and cold rather than 1x vent blowing colder. Looks like I’ll have to book it in. I think I already had the fix (rubber mat) while in for my last service too.Thats the HVAC recall from Lotus, we all been thru that failure.. if not it will come sooner than later.
Hi there, this started for me this morning. Do you have any information on the problem or a solution, or any update from your dealer that may assist? I have emailed my dealer and hopefully it'll be going in soon, but its middle of a very hot part of summer here and i'm hoping this is an easy resolve?Up until 2 days ago my ac system was working just fine… now there us no air blowing from the front and foot vents, only top window vents and not proper cool.
