Clucking sound interior over bumps
harleyujoe
So driver side going over bumps plastic clacking sound
what it sounds like ...
I thought maybe seat but bang it nothing...
Then I thought the bungee going into side panel and taped it and still there..
My thinking now wonder if headliner where it sits on panel..
Any one having this issue...
So driver side going over bumps plastic sounding clucking
My headliner makes a noise at the rear. Almost like a popping sound to me.
Take better care to get all the chickens out before setting off 🐔
My next ride going to try double sticky tape or piece of black foam to see if it stops.. Will let you know
I put the foam between the headliner and back wall and noise is gone...
I will have to replace foam for some type of rubber trim to make it look nicer..
But found the cause of noise.
.Hope this helps you with popping sound of yours Miamiblue..
You have a picture of the location? mine is doing the same, and I am having a hard time locating - its behind my head while driving.
Here is location behind driver seat and will use small rubber door seal for doing final seal finish ..
This noise was really pissing me off for I have Tinnitus and any noise drives me furious..
And my wife does not hear this noise sitting next to me ..OMG
Wonder if the same 1/16in rubber edging that I used for seat to protect the leather from scratching would work? Or is the headliner thicker, and maybe needs a wider channel?
I put that on seat edge also and I did this blind today without light pushing foam up there just to make sure this was noise area..
But think Home Depot 5/16 foam edge for doors will work... Will go get some and let you know later this week..
It's possible that piece is not clipped in properly. I had that area apart recently and it is difficult to properly "click" the clip into the trim piece behind it. While I had the rear trim panels off, I also found some screws that were loose and a missing bracket that a piece of trim is supposed to attach to.
It is possible.. I m 74 and can not bend and see things like years ago... But I just want the noise to go away and if the foam does it
I am a happy person ..for know one will see behind seat ....Maybe when I take it in I Amy talk to dealer..
But the last Lotus Evora I had warranty work done they left me with a dash rattle that I decided to sell it for that reason.
Dealers are to far away to keep running back and forth ..
So foam works and no more noise..LOL. ..So I will keep Emira another few hundred miles...
No more noise putting weather strip between headliner and Back Wall..
I noticed the driver side had a gap of 1/4 to 5/16" and the passenger side was very tight.
I put strip on passenger side to look uniform to driver side..
On Amazon it is called Vital AMO Weather Strip and I found it in Home Depot..
So glad noise is gone and another 600 miles to put it in Sport/Track Mode..
Awesome! I'm going to try this.
so did you just go with a 1/4" for the size? or 5/16"?
Same "rattle"(plastic clack good explanation too!) from dash at base of window going over bumps. Intermittent and changes when dash warms (from sun)while driving and when pressing down with hand on front edge. Loosely fit front dash panel? On list for 1000 mile dealer visit.
I know I have to lift hood up at some point for driver corner has 3/16 movement in hood not tightened down..
So out driving today and noise recurs and now getting pissed ..
So reaching back to rear window I find that the rubber is not stiff enough
to hold headliner the length of rear window from flexing ..
So next ride I rolled up 3M double stick tape about 8 inches long and pushed it up
between the window and rubber to see if this is enough to stop flexing noise..
Next thing will be to use black silicone bead across the whole rear window..
That entire area is not put together well....I'm getting the same sound over bumps, but seems to be right dominant.....this car better rip after break in because my initial powertrain impressions are meh.
touche. I have something on the right passenger side too and yet to track down what. I also have a clicky sound on driver side right above my left ear, and tracked the source to be the manual seat fold lever that is a bit loose. Pretty annoying click clikdy click, but guess is just one of many things that lotus uses to remind you that you are driving a lotus lol
