Clutch malfunction and Gearbox can't shift into gear
Although they fixed my clutch, master cylinder, etc. When I let the car sit for 3-4 days, the clutch gets 'tight' and can't go in reverse on 1st attempt. What I do is 'pump' the clutch a few times and it seems to get the fluids moving and then it becomes less 'tight' and then can go in reverse. I have notified the Lotus dealer, but I don't want to take it in yet until they have parts available otherwise will sit there for 2 more weeks.
How bad is it? Does rolling a few centimeters help instead of pumping? Many Emiras have this and "it's how the gearbox is" :LOL:
It tends to get better with each kilometer driven, but it still happens for me at 20k+ from time to time.
Just want to save you another Lotus trip with probably no fix in sight
TBH, I've had this in many manual cars over the years. I'd go as far as to say it is normal. A trick is to put the lever into first and then go into reverse, usually solves it.
good to know; will try as doesn't go into reverse initially as I let it sit 3-4 days, but doesn't happen when car sits 1-2 days. I am actually frightened to let it sit longer than 4 days as likely won't work (first time I let it sit for 2 weeks as was on vaca even with battery hooked up)
won't take it back to Lotus unless have to
seems pumping helps
hopefully with more miles it gets better
the good news is it forces me to drive the car every 3 days which I love doing
I have the same problem. Went out to drive car, clutch pedal on floor and could not get out of or into gear. Tried pumping, etc and nothing worked so it got towed back to dealer. Sounds just like this problem. Second time going in for warranty work and I also have the "full time" TPMS warning which refuses to go away. Such is life with a Lotus am I right?
Wow man, that sucks. While driving if this happened would be more dangerous. Mine did it while parked. This is ridiculous. Keep us posted on what it is 'this time'. Mine gets stuck from time to time when car sits a few days, but with pumping it usually 2-3 times, it 'gets the fluids moving', if that is even the issue. I recorded what happened today and can hear it get stuck half way up but has enough leeway to come back on its own. Will see if can upload. Car sat 4 days. Almost hard to get in reverse.
Got the car back and its been working so far. Only needed a bleed of the system per dealer. Works better than it ever has.
Wow that was quick...only 8 days, lol (mine was 2 weeks). That is great that only needed a bleed, although that is what they probably told you but needed more, because shouldn't have taken 8 days for a bleed :)
The Video explains it all, but some background. Didn't drive car for 2 weeks, had it on battery charge (was 100% and light green), doors locked.
Come back and cold started, and clutch stayed stuck on the floorboard, and had to pull it back with my foot.
On cold start, the car went red line (can hear it)--2nd video.
Doesn't go into gear (1st video).
Had to crop the video and save in 720p and 480p to be able to upload otherwise was too large of a file.
Turned car off, got out of car, locked it and unlocked it and restarted and same issue.
Called Lotus and they said first time they had this issue, but wondering worldwide if anyone else had this issue of clutch malfunction?
Your description of the clutch problem is exactly the same as with my Emira. Less than 200 miles, parked for a month while out of town, clutch pedal drops to the floor, Emira towed to dealer waiting for repairs. Not an impressive start for the Emira or Lotus. Quality control issue? Probably. Whatever, I expected more from Lotus. Very disappointed
Sorry you are going through this, I was shocked when it happened to me and then later happened again , (not as bad) but I think they learned what the issue was and have had conference calls with other centers to educate the techs on the issue. I believe my car was the guinea pig, and many of the same clutch problems started occurring afterwards on other cars.
Tell them to contact Gio who was great at the Dallas service center as I think he is the world’s expert now on this issue, which I am sure he didn’t want that title but knows what is going on.
Good luck
Having same issues, tough to get it into first and reverse when car is cold started.
Well, mine’s been sitting all winter on the battery tender and I just went to start it and the clutch pedal went to the floor and remained there until I lifted it up. Can’t engage any gear. The car did start normal without any spike in revs. Time to call the dealer.
