virtualmacho
Supporting Member
- Joined
- Dec 21, 2021
- Messages
- 1,140
- Reaction score
- 2,108
- Location
- Tokyo, Japan
- Emira Status
- Emira Owner
What happens when you pre-heat the engine (dunno how, just a thought) ?
No fix yet. It’s a software issue (there was a software update in August but the cold start issue still persists). The engine starts second time because you’ve primed the engine on the first.Just coming up to the magic 1000 miles and my Emira has developed the cold start stalling issue! Began a couple of days ago with very lumpy idle on initial start after standing overnight but recovered with some gentle accelerator application. Today it tried to start then stalled. However started completely normally at the second attempt (as others have mentioned). Only seems to be a problem when the engine is cold and starts normally when warm. Does anyone know if the root cause of this problem has been identified and a fix developed? Definitely a fuel starvation issue but odd it starts completely normally a couple of seconds after stalling through lack of fuel. Almost like the ECU doesn’t compensate the fuel/air mix for a low starting temp at first try but does for the second attempt.
Just to reiterate Kimmax's very astute suggestion...Anyone tried putting the ignition on first and waiting a few seconds before turning over? If it’s really fuel pressure this should work fine, no?
I think you have to press and hold for about 5s to turn the ignition on, no?Just to reiterate Kimmax's very astute suggestion...
Have those who are having cold start issues tried turning the ignition on first to let the fuel pump prime? This is a pretty normal thing with high performance cars.
That's a single press of ignition button (with foot off brake), then a deliberate pause for 2 or 3 seconds, then press brake and hold ignition button to start.
Will give to a try as a short term fix. Bit of a faff if we have to do it all the time. I probably forget tbh.Just to reiterate Kimmax's very astute suggestion...
I thought there was a software fix a few weeks ago that pressurized the fuel via fuel pump running briefly when the doors were unlocked, but this failed to fix the problem. Wouldn't this be similar to switching the ignition on.Will give to a try as a short term fix. Bit of a faff if we have to do it all the time. I probably forget tbh.
Yes, but either way, we're talking about verifying the fuel pump has primed prior to starting the car. In most vehicles you can hear it spin up and pressurize the system.I thought there was a software fix a few weeks ago that pressurized the fuel via fuel pump running briefly when the doors were unlocked, but this failed to fix the problem. Wouldn't this be similar to switching the ignition on.
Well, that seems like a poor UX choice.I think you have to press and hold for about 5s to turn the ignition on, no?
one does yesI think you have to press and hold for about 5s to turn the ignition on, no?
That's not what you have to do for a normal start though - just a single press.Well, that seems like a poor UX choice.
Agree, you should be able to hear a whining buzzing noise after you unlocked your car on most push start button cars I’ve owned. Not on the Emira though.Yes, but either way, we're talking about verifying the fuel pump has primed prior to starting the car. In most vehicles you can hear it spin up and pressurize the system.
But I do have the climate fan running on unlocking, which stops when I open the boot to remove the battery conditioner connection or open the driver's door.Agree, you should be able to hear a whining buzzing noise after you unlocked your car on most push start button cars I’ve owned. Not on the Emira though.
Yip agree, fans comes on, wireless Apple CarPlay comes on, unfortunately they don’t prime the engine. The cold start issue is completely random. Most times, it starts first time but very lumpy. Second time is perfect.But I do have the climate fan running on unlocking, which stops when I open the boot to remove the battery conditioner connection or open the driver's door.
Tried starting the car this evening after leaving for 24h. Followed Kimmax’s suggestion and activated the ignition without pressing the clutch (had to wait around 10 seconds for the display to light up!) then a further 10 secs before depressing the clutch and pressing the starter. Result - success! Engine started 1st time and ran normally. Was listening out for electric pump priming noises but nothing of note other than the cabin air fan starting up when unlocking the door. I agree it does seem to be a fuel pressure/pump priming problem.Have those who are having cold start issues tried turning the ignition on first to let the fuel pump prime? This is a pretty normal thing with high performance cars.
Be advised the car will also start with only the brake pressed - keep that in mind if you park in gearTried starting the car this evening after leaving for 24h. Followed Kimmax’s suggestion and activated the ignition without pressing the clutch (had to wait around 10 seconds for the display to light up!) then a further 10 secs before depressing the clutch and pressing the starter. Result - success! Engine started 1st time and ran normally. Was listening out for electric pump priming noises but nothing of note other than the cabin air fan starting up when unlocking the door. I agree it does seem to be a fuel pressure/pump priming problem.
What? Emira doesn't have a Clutch interlock switch with the ignition? I thought every manual tranny car had this safety feature?Be advised the car will also start with only the brake pressed - keep that in mind if you park in gear
This safety feature will allow you to hobble out of danger's way when the ignition subsystem fails in the middle of a railroad crossing.
Has anyone tried double revving on a cold start? | Lotus Emira Talk | 14 | ||
No oil temperature gauge? Driving pattern on cold start? | Lotus Emira Questions | 9 | ||
K | Do people really dislike the covered start button? | Lotus Emira Talk | 69 |
