Cold start stalling
I have an OZ car and was having the stuttery cold start issues. At the time using BP 98 fixed the issue, except BP 98 from one (smaller) outlet which seemed to bring the issue back. Each time I filled I made sure I was nearly empty to check which fuels helped and which didn't.
The issue completely went away after a software update early 2024 (I can use any brand 98 fuel now). Although, another issue came about immediately after the early 2024 update - not cold starting at all! You'd have to open & close the door, lock, unlock, then try and it worked after that. Was quite annoying. Then another software update and that issue seemed to disappear as well.
Thankfully no issues with starting since. For me at least some of it was software and some fuel sensitivity related. I gather people who are having the issue now are fully up-to-date software-wise.
Reactions: SJM
I know this isn't something you should have to do, nor is it going to be popular to say this, but I replaced the factory battery with the 40ah Antigravity battery from GRP and I've never had a single issue starting the car. I've gone as long as a couple of weeks without starting it, and it started right up, and that was without ever putting it on a battery tender.
The Antigravity battery isn't cheap, but it will remove about 30 lbs of weight in the back which is a nice extra bonus. There's something about the factory batteries that just isn't up to snuff. I suspect it's similar to what happens with cell phone batteries, where even though they test good, and show they've charged to 100%, over time they steadily degrade and hold less and less of a charge amount. Showing it's charged to 100% only means it's charged to the maximum of the lesser amount of charge it can hold, which is not the full amount it originally could.
This is what I think is happening with the factory batteries that sat on pallets for who knows how long before being charged and installed in cars on the production line. Some of them are weak; some weaker than others. I'm gonna guess that if those of you having these starting issues try an Antigravity battery, your cars will suddenly start fine and continue to start fine.
I don’t think this is an unpopular opinion. I intend to replace my battery with the antigravity one as soon as I my battery goes or I have any issues. Should be more reliable and has a massive weight advantage. Sure it’s expensive, but the car wasn’t cheap.
Just to jump in on this one..
I started having this issue. Car ran fine once started, but if left it off for a couple of days the start would seem like it would stall. Battery was definitely fine (checked voltage), and also kept it on trickle.
I changed from Shell's VPower (E5 / 99 RON) which I've used on all my cars for well over a decade... switched to Shell's standard E10 / 95 RON, and the cold start is perfect. Definitely seems to be some sort of fuelling / software issue on startup!
Can anyone suggest a technical reason why lower RON/higher ethanol fuel would solve startup issues?
My dealer did tell me when picking up the car to use 95 E10 fuel as that was what Lotus specifically tuned the car to use and recommended. But I struggle to think of a reason why using 'better' fuel should cause an issue.
If it makes any difference I've only ever used the recommended fuel and have never had a starting issue (touch wood I haven't jinxed it now!)
The issue is due to communication timing between the TCM/VDDM/ECM.
Lotus advice is “The guideline we have given the dealers if this rare occasion happens is to allow a minimum of 27 seconds between unlocking the car and starting the engine.”
However, a software fix has been released to the dealers for this last month.
Yeah, I’m going to try 95/E10 here in Australia.
Engine light doesn’t come on as often just lately but cold starts always stall.
Would be nice if dealers here have owners more information on this issue!
If there has finally been a fix released I’ll be calling the dealer Monday morning.
Thanks.
Can you post / reply if your dealer confirms software fix is available. Thanks mate
Hello mate. Short answer is yes.
There is a software update as above which apparently sorts out this issue.
My car is now booked in in a few weeks to get this and another three or four updates / fixes that I didn’t know about.
I have to be honest and say while I’m glad this is being done I’m a little disappointed I wasn’t notified of the other updates as they became available.
I would have expected a phone call every time something was updated or needed fixing.
It really shouldn’t be up to the owners to chase fixes for issues.
Anyway, hopefully this flaw will finally be sorted.
If you get your car in before me to get this update please let us know if it works.
Hey mate, how'd it go with the software updates for the cold start issue ?
I haven’t had this in a long time now and I was affected often. It seems like there wasn’t "the" update to fix this, but multiple one after one dialing it in to where it needs to be.
HOWEVER one update between Apr 2nd and Mar 25th seems to have fiddled with the startup rpms. Since having this update applied the car seems to start much "stronger". I have no proof but it sounds like maybe 150-200rpm more and feels much more robust now
The car goes in next week so will let you know.
I really hope it fixes the problem as it is worse than ever now.
Doesn’t matter what I do, it stalls every time if cold.
(The previous procedure I was using worked for a while but not any more).
My car went in today, 5/5/25 at Zagame Adelaide, to have a software update (cold stalling, engine light) among other factory fixes like water shielding.
Will post the results when the car is back.
my car has all available software updates on its recent 2nd service a few weeks ago and now the cold start issues using 97/98 RON fuels has not reoccured in two fill ups and around 4 cold starts.
Good to hear. Looking forward to your thoughts.
Mildly pissed that they told me no appointments available until next week (12/5) when I called nearly a month ago to book it in…
I had this problem pretty consistently for the first few months too. Now, and for the last ~6 months, I don't have it at all (knock on wood). I have done no software updates since delivery, and can point to no changes in driving habits. Who knows why this fixed itself, but I hope it stays that way.
I can confirm the software fix installed last week fixed the issue for me - along with the 'Limited Telematics' error.
Had my starting software updated at Brisbane Lotus last Thursday at it's year 2 service. They said the update was just released and they had only applied it to one other car at that stage. I've had the car, V6 manual, a couple of months and it failed on first start attempt every single time. 1st day after the update it almost started first time, but It's started cleanly every day since. Very happy.
