Cold start stalling
My car has the stock battery, is now 7000 miles and 18 months old, and it's never failed to start & run as it should.
Same me, stock 23 months old battery, 20k km on it , and some 2-3 weeks car parked and never failed start
I have an OZ car and was having the stuttery cold start issues. At the time using BP 98 fixed the issue, except BP 98 from one (smaller) outlet which seemed to bring the issue back. Each time I filled I made sure I was nearly empty to check which fuels helped and which didn't.
The issue completely went away after a software update early 2024 (I can use any brand 98 fuel now). Although, another issue came about immediately after the early 2024 update - not cold starting at all! You'd have to open & close the door, lock, unlock, then try and it worked after that. Was quite annoying. Then another software update and that issue seemed to disappear as well.
Thankfully no issues with starting since. For me at least some of it was software and some fuel sensitivity related. I gather people who are having the issue now are fully up-to-date software-wise.
Reactions: SJM
I know this isn't something you should have to do, nor is it going to be popular to say this, but I replaced the factory battery with the 40ah Antigravity battery from GRP and I've never had a single issue starting the car. I've gone as long as a couple of weeks without starting it, and it started right up, and that was without ever putting it on a battery tender.
The Antigravity battery isn't cheap, but it will remove about 30 lbs of weight in the back which is a nice extra bonus. There's something about the factory batteries that just isn't up to snuff. I suspect it's similar to what happens with cell phone batteries, where even though they test good, and show they've charged to 100%, over time they steadily degrade and hold less and less of a charge amount. Showing it's charged to 100% only means it's charged to the maximum of the lesser amount of charge it can hold, which is not the full amount it originally could.
This is what I think is happening with the factory batteries that sat on pallets for who knows how long before being charged and installed in cars on the production line. Some of them are weak; some weaker than others. I'm gonna guess that if those of you having these starting issues try an Antigravity battery, your cars will suddenly start fine and continue to start fine.
I don’t think this is an unpopular opinion. I intend to replace my battery with the antigravity one as soon as I my battery goes or I have any issues. Should be more reliable and has a massive weight advantage. Sure it’s expensive, but the car wasn’t cheap.
Just to jump in on this one..
I started having this issue. Car ran fine once started, but if left it off for a couple of days the start would seem like it would stall. Battery was definitely fine (checked voltage), and also kept it on trickle.
I changed from Shell's VPower (E5 / 99 RON) which I've used on all my cars for well over a decade... switched to Shell's standard E10 / 95 RON, and the cold start is perfect. Definitely seems to be some sort of fuelling / software issue on startup!
Can anyone suggest a technical reason why lower RON/higher ethanol fuel would solve startup issues?
My dealer did tell me when picking up the car to use 95 E10 fuel as that was what Lotus specifically tuned the car to use and recommended. But I struggle to think of a reason why using 'better' fuel should cause an issue.
If it makes any difference I've only ever used the recommended fuel and have never had a starting issue (touch wood I haven't jinxed it now!)
The issue is due to communication timing between the TCM/VDDM/ECM.
Lotus advice is “The guideline we have given the dealers if this rare occasion happens is to allow a minimum of 27 seconds between unlocking the car and starting the engine.”
However, a software fix has been released to the dealers for this last month.
Yeah, I’m going to try 95/E10 here in Australia.
Engine light doesn’t come on as often just lately but cold starts always stall.
Would be nice if dealers here have owners more information on this issue!
If there has finally been a fix released I’ll be calling the dealer Monday morning.
Thanks.
Can you post / reply if your dealer confirms software fix is available. Thanks mate
Hello mate. Short answer is yes.
There is a software update as above which apparently sorts out this issue.
My car is now booked in in a few weeks to get this and another three or four updates / fixes that I didn’t know about.
I have to be honest and say while I’m glad this is being done I’m a little disappointed I wasn’t notified of the other updates as they became available.
I would have expected a phone call every time something was updated or needed fixing.
It really shouldn’t be up to the owners to chase fixes for issues.
Anyway, hopefully this flaw will finally be sorted.
If you get your car in before me to get this update please let us know if it works.
