Corrosion Protection Spray
harleyujoe
196
136
Has anyone over the years with their Lotus used any spray protection on Aluminum
suspension / transmission to maintain them from corroding??
I just sprayed my transmission housing with CRC Marine corrosion inhibitor... it had a bunch of white flaky crap on it that I noticed when doing the short shift mod. It seemed to work well. (Before pic below)
I just sprayed my transmission housing with CRC Marine corrosion inhibitor... it had a bunch of white flaky crap on it that I noticed when doing the short shift mod. It seemed to work well. (Before pic below)View attachment 57864
Do you have after Picture you can share.. Is this something you will need to spray few times a year ??
I sprayed everything around the engine with ACF-50 per recommendations on this forum. Seems to be doing its job. I didn’t do the suspension, but I think it would work well for that too.
I know the UK has some spray called XCP Clear and rated very high and see new spray called Mac Off HCB 1 .
Did the ACF 50 seem oily and did you have to wipe it after applying ???
I have a can of ACF-50 ready to go, but I'm still trying to figure out how best to clean/polish things up before laying down the protectant spray. My supercharger especially looks like it could do with some buffing up due to surface corrosion. Getting the wheels off and doing all the suspension arms etc is probably a good shout (y)
Presumably using a metal polish beforehand is going to interfere with the protectant spray... anyone got any insights or experience there?
I didn’t clean or prep anything. Just sprayed it on the first week I received the car. It did run a bit and collect in areas. See pink liquid in attached picture. I didn’t bother wiping it but you certainly could.
This isn't the same as the "usual" undercoating "black goo" I've tried on a grand total of one new vehicle in the past. I hated the burning smell of that substance, which took some time to wear off...likely from contact with the muffler system or other hot engine components. Hopefully this CRC Marine corrosion inhibitor or ACF-50 doesn't come with that smell, which can be disconcerting.
I don’t really know. I’ve had vehicles undercoated by Krown and they smelt like burning oil for a couple weeks. I could smell the ACF-50 for a day or two, but that could just be a difference in how much I applied and where I put it.
I used Bar Keepers Friend, liquid and small brushes/clothes to clean light reddish/orange surface rust fro aluminum SC body. Works great with little effort; use it often on metal items with surface rust......
