Tim
Active member
Finally got round to fitting my Thinkware F800 Pro from my old car to the Emira. I like to use the hardwire kits so I have parking mode.
Taking apart a car where I couldn’t find any previous “how to” guides is always a fun challenge. Fortunately the Emira is pretty easy and I went super slow as I didn’t want to mark any of the trim.
I really should have taken better photos as I was doing this, but shout if anything needs clarifying!
A Pillar Trim: two clips - top one is captive so it’s easier to slide it off with some long nose pliers and then recover it afterwards.
Filler between door and dash: Simply unclips (two clips on right hand side). Left is held by door rubber.
Glovebox: One screw under filler above. Three inside under a cover by the latch that unclips easily. Lastly two M6 bolts underneath. Easily drops out when you unplug the passenger airbag switch.
Rear-view mirror surround: Unclips and easily pried with trim tools.
Routing: Followed a ground strap from footwell to the door. Then up and behind the airbag using clips all the way up the pillar. Tucked behind roof lining to the mirror housing. Used the vent at the bottom to bring it out in the right position for the cam.
