Thanks for the writeup @Joel and @somer82.
For a two channel camera can it be mounted to the rear hatch glass at the top? How long of a four-conductor wire do you think is needed to go from the boot battery location to the windscreen?
I'm looking at installing a thinkware u3000 and battery so it's rear fuse box to the rear mounted battery pack, then four wire to the windscreen, and from there back to the rear camera. Just trying to plan things and this is definitely a stretch for me.
First up, trying to get the toeboard off to get to the fusebox. For some reason this proved very difficult in my car. Likewise, getting it back on also proved very difficult. Probably the hardest bit of trim I had to remove throughout the entire process, which is surprising since it's "user serviceable" right? Did others get theirs on/off easily?
Seems there's a lip it clips underneath on the bottom side which I think was causing me issues, as well as some ill fitted carpetry.
Once I'd got into the fusebox area, I realised my battery was never going to fit!
Unrelated, but do none of the cars come with tweeters? Is this a mistake?The manual makes it seem easier than it actually is (VOE).
The upper clip is captive (I think to keep the trim in place if the curtain airbag goes off).
The trim will pop out about an inch and then get held in place but the clip is in a slot in the trim from which you can pull it upwards and out with a trim tool or similar. You can then extract it from the A-pillar for re-fitting. The lower clip comes out fine.
I’ve had mine off several times in the never-ending saga of my windscreen replacement.
(I’ll bore you all with that story if and when it reaches a conclusion. I’m currently waiting for Autoglass to schedule a fourth attempt).
While they were off I filled the unused tweeter hole with some handily same-coloured foam.
They do, they are just not in the A pillars. Those empty slots are for when the base audio system comes along.Unrelated, but do none of the cars come with tweeters? Is this a mistake?
That panel is a pita to put backI'm wiring up a blackvue dashcam today and decided to use the footwell fusebox. Man, this panel with the four quarter turn screws is not easy to get out. Maybe it'll be easier if I loosen all the glovebox screws and shift the glovebox out of the way (not remove it completely or disconnect airbag cable. Routing the camera wire from the rear view mirror down to the glovebox area was pretty simple. Just push the wire into the crack and lift the edge of the trim (headliner or a-pillar) until the wire falls behind the panel.
Is the fuse box behind the passenger seat easier to access?
I’ve heard this from everyone, I look forward to this little slice of hell.I'm wiring up a blackvue dashcam today and decided to use the footwell fusebox. Man, this panel with the four quarter turn screws is not easy to get out. Maybe it'll be easier if I loosen all the glovebox screws and shift the glovebox out of the way (not remove it completely or disconnect airbag cable. Routing the camera wire from the rear view mirror down to the glovebox area was pretty simple. Just push the wire into the crack and lift the edge of the trim (headliner or a-pillar) until the wire falls behind the panel.
I love this idea if possible. Simple and elegant. Anyone try this? Any suggestions? I'm installing a Vantrue Nexus 5 with parking mode and this would be preferable to running a hardwire.Fuse NR 54 is described as
Theoretically can’t one bridge that fuse into another always on one? Best case one of the spares is always on with the same rating?
Would remove the need to run a new wire and makes use of the rear view usb instead. Of course not draining the battery using either of the usb ports is now your own responsibility
Thanks for the writeup! I'm curious based on where you installed the rear cam, does it provide a nice view of the engine and throttle action? I was thinking that could be a nice addition for YT content if it's in the field of view.Ok so I fitted my dash cam today, some parts were easier than others I found out.
So switch to plan B, I had to put it under the passenger seat. This was fine, routing the cables to the back of the car was easy, managed to tuck them under the central console. I did hit an issue though, when trying to move the passenger seat back, the battery didn't actually fit underneath and scraped against something underneath, oops.
In the end, the battery ended up velcro'd vertically behind the seat, will have to be cautious with taller passengers and make sure they don't crush it!
For fuse tapping, I ended up using the spare fuse 52. This is rated at 10amp in the Volvo XC40 and while it only has the positive connection, if you set the fuse tap correctly you can leverage that to power your cam/battery. A simple multimeter test proved it was a switched fuse which is what's needed for the Cellink Neo 8+ I've installed, which has a maximum draw of 9A.
The wiring ended up looking like below by the time I'd finished. Though the fuse cover did fit nicely on, it has gaps where the two cables are coming out at the bottom.
The rest of the process was actually relatively straight forward, the A pillar and other trim bits came of more easily than I had expected, though the plastic cover behind the mirror was a little fiddly to put back.
Since I have a two channel dash cam, I had to wire a cable up to the back. To avoid interfering with the airbag, I ran the cable all the way around the airbag and then up the inside of it and under the door seal, should be well out of the way looking at the path the airbag takes up into the roof.
For those of you wondering about the retained clip inside the A pillar, I tried to capture what that looks like here. This picture is looking down towards the dash. Pop some pliers in there and pull the metal piece up a couple of cms and it comes out.
In the end, all that's visible really are the two cameras, though the front is masked by the mirror in my normal seating position, and the rear is so small you don't really notice it in the mirror anyway.
The only other takeaway I have from this experience is that today was a terrible day to do this, in 25 degree heat, in the sun, the car became a greenhouse and I was sweating by the time I finished. I'd recommend finding a slightly cooler day for anyone planning to do their own install![]()
