DIY: V6 Manual 1st, 2nd & Reverse Adjustment - Hard To Get Into Gear
In the posts above? Youtube link?
Hard to get a 'better' video than that because its a tight space and your hands and the shifter will be in the way of any meaningful views.
Did you ever get around to doing that video? Inquiring minds wanna know (and possibly proceed with your help) :)
Thought I posted it here:
Woops... yep.. I missed that... THanks!
Had a journey this week and struggled to get into first and second for a 75 mile journey - it came and went but was “interesting”. I panicked thinking I’d got some horrific issue, followed this and hey presto it’s all sorted.
My adjustment nut was VERY loose!
Hey kitkat, what exactly do you mean by not smooth? For mine, getting into 1 and 2 it feels a bit rough, sort of like a rocky feeling. If I go back into neutral and then try again once or twice more, it feels smooth. Is this the feeling you’re referring to?
If you go into first from neutral at a stoplight to get started, do you find it easy or difficult to get into first gear, like physically getting it to there or does it sometimes feel like you’ve missed the shift gate. Do you ever find it easier to shift into seconds and then first?
If you can resonate with those you should adjust the lockout plate.
Okay got it. For me, 1, 2 and reverse are rough to get into and I question whether it is fully in gear or not.
100% do the procedure then, the lockout plate adjustment will fix this, it'll make your car so much more enjoyable to drive.
After installing the GRP short shifter, I found it harder to get into 1st and 2nd gear. It wasn't a problem before the install. Does anyone else experience the same? I will try the adjustment to see if it helps.
I found mine would sometimes struggle to go into reverse without requiring some force. Someone told me to put it in 1st briefly before going into reverse. This seems to work, and it then glides into reverse. I'm not sure why this works.
I should probably try this adjustment, but I'm hesitant in worry of breaking something.
I've also driven 3 different Emiras. All 3 had a gearbox that felt quite different to operate.
Why is it so inconsistent between cars? Do they even bother setting them up properly at the factory?
Do the adjustment you'll wonder why you hadn't earlier, it's super easy.
Likely the poor guy who has 18 minutes to install the whole shifter assembly and adjust the cables just didn't have time to do it perfectly. This is Lotus we're talking about afterall.
I’m running into this issue. Just curious, anyone had their dealer fix this or is that a bad idea?
I’m nervous to try and fix this lol. It’s my first fancy car and I always break stuff when I work on my cars.
Your dealer should be able to handle it just fine, tell them the reverse lockout plate needs to be adjusted.
@kitkat I'm at about 3K miles on my car and drive it like it's meant to be driven -- I have the GRP short shift installed (set in as received position) and like it very much -- the single complaint I have with my car is the shift from 1st to 2nd, no matter the RPM. It's a 2 step process -- pull down (feels like it finds a notch), then pull down again (into gear)...similar situtation 3 to 2 with rev match. Not smooth whatsoever, I dont think I could make the shift without a firm grip on the shifter knob.... all other gears are butter and require little effort. The 2 step process is painfully slow, do you feel the adjustment described in this thread would address this concern? Thanks for your input!
I think what you’re describing is more intrinsic to the Emira transmission unfortunately. Anything dealing with 2nd gear for me is a little slow or forced. This adjustment only fixes any binding you might have between with 1-2. It doesn’t hurt to try, and it’s such an easy procedure.
I thought that might be the case, but as you mentioned it wouldn't hurt to try it anyway. Thanks bud.
