DIY: Manual Clutch Slave & Brake Fluid Replacement/Bleeding
jp129
I didn't see a guide on replacing/bleeding the Brake/clutch fluid so, I've put one together.
This information is purely my experience and serves only for your entertainment. I will not be liable or held responsible in what you do with this information. Please proceed at your own risk.
Tools needed:
8mm Open ended wrench
11mm Open ended wrench
T-30 torx bit
Pressure bleeder kit with 45mm European master cylinder reservoir adapter
Clear tubing for bleeder valves & Container to catch fluid (included in the kit above)
Favorite DOT 4 brake fluid
Towels/rags for clean up
Access:
Open front service access cover. Pop the three plastic covers and unfasten the T-30 torx bolt with the provided tool in the tool kit or T-30 Torx bit.
Remove the plastic cover on the driver side (LHD) by twisting the plastic fasteners 90 degrees.
Remove cover to explose the brake/clutch master cylinder reservoir (they're shared).
I used pressure bleeding tools to perform this job since it is much easier and faster, with better results.
This particular kit comes with the "European 45mm" adapter that works on our master cylinder reservoir.
Install the bleeder adapter. Pump the pump up to 10-15 PSI. Connect the pump to the adapter via the QD and slowly open the valve to check for leaks.
If no leaks are present, close the valve, slowly remove the QD from the adapter. Depressurize the bleeder pump and fill up the brake bleeder with your favorite DOT 4 fluid. Pump the pump back up to 10-15PSI.
BE CAREFUL WHILE HANDLING BRAKE FLUID. IT IS EXTREMLY CAUSTIC TO PAINT. If you spill any on your paint, immediately clean it up with water or risk paint failure.
Connect the the QD connector back to the master cylinder reservoir adapter.
I chose to flush the clutch master cylinder fluid first. I don't think it matters as long as you do both the clutch and the brakes.
Access to the clutch master cylinder:
Open the hatch. Remove engine covers and locate the clutch slave cylinder. It will be towards the front of the tranmission, right next to the exhaust manifold heat shield. Going from the top seems to be the easiest way to perform this job.
Once you locate the slave cylinder and bleeder screw, remove the protective rubber cap.
Place snug clear tubing or utilize the 90 degree elbow adapter for brake tubing that was provided in the kit I linked. This makes it easier and less messy.
Once you have a container ready to catch the fluid, you can get ready to flush the fluid.
Tip: put a towel right underneath the bleeder valve. This will help catch any seepage.
If you haven't already pressurized the reservoir, go ahead and do so now. Once pressurized, head back to the slave and open the bleeder valve. It is a 8mm hex.
Open the bleeder and watch the fluid. After you feel sufficient fluid has been replaced. Close the bleeder.
At this point, I chose to test the clutch pedal feel before buttoning everything back up. If you feel the pedal is mushy or doesn't feel right, keep bleeding. If everything feels good. Remove your tubing, have a towel or rag handy as there will be some spillage.
Replace protective cap. And reinstall all the engine covers. Job complete for the clutch fluid.
Brake fluid replacement:
After the clutch fluid is replaced, I flushed the brake fluid. Same setup procedure for the master cylinder reservoir.
Pop off the rubber protective covers on the bleeder screws. There are 2 bleeder valves per caliper, one on each side.
Attach your hose to the caliper bleeder screws. They are 11mm hex.
Ensure that your pressure bleeder still has sufficient fluid and sufficient pressure from the clutch fluid replacement.
I chose to go Left Rear, Right Rear, Right Front, and Left Front calipers. I honestly don't think it makes a difference, but I'm just used to doing this on all my cars.
Once you have a container to catch the fluid, crack open the bleeders and watch the fluid.
Close the bleeders once you feel you've sufficiently flushed the brake fluid. Rinse and repeat for each caliper.
Clean up any seepage from the bleeder valves as it may impact the finish on the caliper.
Once finished, replace protective cover. Job complete.
Dispose of your used brake fluid responsibly. Bask in the glory that you likely saved tons of money vs going to the dealer, performed the job right, and keep your car happy! Enjoy!
How do you reach the bleeder? I've heard people sit in the trunk, but i weight ~230-240lbs and am not sure I want to do that.
Yes, so that's what I did, sit in the trunk.
You could try a top side creeper if you want to get at it from the top, if not, it'll have to be from the bottom. I only find the top easier from a visual perspective. You can clearly see everything. If you go from underneath, you won't be able to see everything, it'll have to be by feel.
I think the preferred term in 2025 is enslaved cylinder.
I was missing a few pictures from the procedure. Just added a few more for clarity.
Great write up. Thanks!
Did you leave the wheels on for this job? Just put a hose on the bleed valve?
I did and you can if you're only looking to replace the fluid. The wheel spokes may limit your wrench range, so that may not work if you're using the box end.
If you have air in the lines and looking to bleed the brakes, it's best to bleed from both bleeders to ensure there's no trapped bubbles on the other side of the bleeder.
For everyone it's important to understand why this does matter. Conceptually, what you are trying to do is "clean the longest path" to ensure any closer (to the master cylinder) diversions (each wheel, etc.) are only getting new, clean fluid when bled. So, the way you should think of it, pick the location furthest away and start there, then work your way back to the closest using the next furthest away and keep doing this until you get closest to the master cylinder and that would be last.
For the Evora or Emira, I would have done right rear, left rear, clutch slave, right front, left front. Also, do not go dealer lazy and only do the front bleeder of each caliper (yes, every dealer does this, trust me). Bleed both! Otherwise, over time you will have a small amount of extremely degraded fluid in each of the calipers all because people were lazy.
I just replaced the brake fluid myself last week too with basically the same tool, but I skipped the clutch cylinder because it was very difficult to reach. One thing that confused me was I cannot tell the brake fluid level in the reservoir with the cap on. At the final step when all the new brake fluid has been pumped in, I had to remove the cap to make sure the level is not too low.
It'll seem tedious, but if you are doing a manual bleed with just pressure (which it sounds like you did), just check the level and add after each wheel. Or, if you are using a pressure bleeder with new fluid in there and not just the air pressure, then you don't have to worry about this other than topping it off at the end when you remove the pressure cap.
Yeah good call but I poured all the new brake fluids into the pressure bleeder so I cannot top it off anymore if it went too low. 😂
