Or readjusting he door rubber ..lets say it wasn't installed perfectly, I would undo a section and flatten it out make it fit better or in corners if it was short,, use hand and hit it into corner for tighter fit. a I'm not too good at explaining in words.. Would take literally 15 seconds to show someone how to finesse everything and get a perfect fitment.The trim tools I used were the same ones you could use for radio replacement, just various size and shape plastic things. Just took a flat one under the rubber to unhook it. And yeah the massaging was basically just using a bit of pressure to push it into all the corners like you would with a carpet.
