Emira Lightweight Alloy Forged Wheels by Aerie Performance
No. From the manual it looks like we can reset them ourselves. It may be worth noting I don't have a car. @JonFuller just got his installed though. Jon, did you have to do anything special?
There is no manual reset for the TPMS. It is supposed to auto-read and adjust/reset the existing programmed sensors. I previously had some TPMS sensor issues (including the warning light which was unable to turn off on its own) and the dealer had to clear the code. I also asked about new sensors and they said new sensors are required to be coded to each car specifically.
A couple of shots comparing the Aerie wheels to the stock ones.
Hi Aerie,
Do you make 11 inch V2 wheels or can you confirm if 305 tyres would fit 10.5 rims?
I posted a thread about a possible wheel and tyre combination but so far no replies on it:
If you look up tire specs they will tell you what the recommended wheel width range is for a given tire size.
In this case, yes, a 305 section tire will fit a 10.5in wide wheel.
Can you make a set like this?
Front: 9J x 19 ET52
Rear: 10.5J x 20 ET54
Hi Finny76, are you still looking at a 19 inch front wheel and if so what tyres were you thinking of?
I can’t find the post but someone said they might get some 18 inch track tyres.
I see the GT4 has 28s and did a bit of research to try and find out why if low profiles are supposed to give better grip and performance. Eventually I found out 2 things:
1. There are just as many opinions saying bigger tyres are better for racing than low profiles for heat, grip and durability with the complete opposite being said about them.
2. The GT4 has suspension designed around the tyres acting as a spring to provide squash which complements a really hard chassis set up. Looks like a swap to those wheels and tyres would be worse for our cars.
Any views because I think think a set of V2s on 18s would look cool?
I changed plans on getting wheels, and im going to wait to get the car before i decide to get wheels blind without knowing how much clearance i would have etc etc.
Has anybody received their wheels?
I ordered a set in January, I have sent repeated messages, occasionally I get a response saying they have been shipped and will get back to me with shipping info and then nothing.
Am I being ghosted?
I received the carbon engine surround no problem but the wheels seem to be either lost or maybe Aerie got lost??
Am I being ghosted?
Hi Martylemoo
We received your email enquiry on last day and we asked shipping agents the delivery detail and they just got back the response to us today and apologize for the late reply ,
Currently your wheels package are now in British in customs clearance and we will arriving to you very soon .
We will send you the detail via email later today.
Am I being ghosted?
I received the carbon engine surround no problem but the wheels seem to be either lost or maybe Aerie got lost??Can you post an update when you get
Am I being ghosted?
Can you post an update when you get them? What’s the weight like, finish and fit etc… I’m super interested but want to see how someone else’s experience goes first!!!
Got my custom colour and offset wheels on the car yesterday and very happy with them.
Removed 6mm rear and 5mm front offset to make them 1mm shy of flush.
Lookin' good! I like the plates as well :D
Do you think there is any danger of rubbing on the arches with those offsets? It's probably the main thing that puts me off ordering with a custom offset... but the idea of spacers doesn't thrill me either.
