thanks for the code data! was this at Lotus NJ?I got my car back.
Here is what stated on the work order - ECM-P045100 and ECM-P044600 stored active. Fault tracing with Lotus FTS lead to the discovery of fuel bleeding into EVAP canister via EVAP tank valve.
Replaced EVAP canister and EVAP valve as per FTS.
I will have to drive the car for 50 miles or so to see if the check engine light returns but Lotus is positive the issue has been resolved.
Yes, Lotus of North Jersey in Summit, NJthanks for the code data! was this at Lotus NJ?
A data point - it took almost 2 weeks to get the canister from the UK. The valve was available at the dealer.Same problem here after owning the car for two days. Hopefully the parts arrive soon.
Depends on if your dealer is one of the friendly or stick to the rules kind. Officially you'll at least put a "who is at fault" on the table if you keep it modified.If I have to take it to the dealer, should I put it back to stock before I put in for service?
