MajHall04
Can anyone confirm that if you pull both paddles back on the I4 it goes into neutral ?
Its not a rarri or bullCan anyone confirm that if you pull both paddles back on the I4 it goes into neutral ?
https://www.lotuscars.com/en-GB/emira-handbook - main handbook page 188 but yes, both V6 auto and i4 do that....However "NOTE: The brake pedal must be depressed and the ignition must be in mode II before you can select any other gear from N." and then "NOTE: The brake pedal does not have to be depressed if the current vehicle speed is over 5mph" so I haven't tried it on the move yet (V6 Auto)...Can anyone confirm that if you pull both paddles back on the I4 it goes into neutral ?
N | Flappy Paddles experience on autos | Lotus Emira Questions | 11 |
