Is anyone running 19" track wheels?
OppositeLock
Does anyone know whether 19" wheels fit on the car? I did some rough measuring, and I know an 18" wheel won't fit in the rear, but it looks like a 19" might. An 18" wheel should fit in the front.
The 20 inch wheels on the car really limit tire choice, and I destroyed my set of OEM Goodyear F1 Supersports at Laguna Seca. I'm going to put some street tires on the 20"'s and I'm hoping to downsize for the track. More sidewall means lighter wheels, better bump absorption, and lower tire costs.
I asked @GRP about smaller diameter wheels (they had the 18" Braid motorsport wheels listed on their site, but I don't see them now).
They said the Emira parking brake definitely interferes with 18" wheels, and might interfere with 19" wheels. They said they would investigate and follow up at some point.
Hopefully GRP will be able to answer the OP question.
This is off-topic but related: this post got me wondering if there was any advantage to using dedicated track tires on the track, rather than street tires. Here's a discussion on reddit, amongst people who track their cars so should know what they're talking about, in relation to how long tires made specifically for the track, last. Some comments should also apply to street tires, in terms of your driving style. I was particularly interested in comments mentioning tires "degrading" when exposed to UV (sunlight) or cold temperatures, since I was considering storing a spare set of tires outside during the cold winter months (apparently not a good idea, at least for track tires), before I recently created more room in my heated garage:
And here's another interesting discussion confirming that track tires don't last anywhere as long as street tires, but they're far more "sticky" for those looking to get true performance on the track with their tires:
Once you try track tires, you'll realize how terrible street tires are on the track.
(I guess Cup 2 MIchelins are kinda more track tires than street tires, so those should be fine.)
I had a Porsche 944 Turbo Cup factory race car that I bought new and had for 29 years (now owned by Mr. Seinfeld), and I usually used Hoosiers R7, but also tried others that were pretty good. The Hoosier's don't last long, but there are a bunch of "200TW" (200 treadwear rating) tires that are still really good and will last most folks a season or two. BTW, I never did "real" racing, just DE events with BMWCCA and PCA, and also several years with Brian Redman's Targa 66 track group.
The magazine Grassroots Motorsports does very detailed testing of track tires, very useful. Scroll waaaaay down to the bottom for a chart of all tires. This is a year old, my guess is they'll be updating it soon.
EDIT: Probably modern ultra high performance street tires are ok on track when the tread is worn down halfway or so.
Yeah, I've contacted GRP a few weeks ago. As soon as they tell me that the wheels fit, I'm buying a set from them. I also suspect it might be possible to reconfigure the rear parking brake gearbox and turn the motor inwards, towards the center of the wheel. If I can find some time, I'll see if I can make a prototype that clears an 18" wheel. There's no reason for that thing to stick out so much.
I've done several hundred track days on my Elise, I lost count of how many a good decade ago, and early on, I realized that a dedicated track wheel set is a must.
First, until you sort out the car as you like it, you will be experimenting with tires, pads, all kinds of stuff. Some pads (like sintered metal ones) are hell on wheels, and I don't want to mess uo my pretty Emira wheels, since I'm going to keep this car pretty.
Second. Track focused tires can handle heat better. The Goodyear F1 SuperSports on my Emira were good for the first 10-12 minutes of a session, and then they started to get greasy. I had the same problems on the Elise as well. Once you get into the barely streetable tires, like Bridgestone RE71RS or Toyo R888R as examples, you will have higher performance for more of your session. I used to run the Yokohama A005 soft slicks on my Elise, and they got me 3-4 seconds a lap at Laguna Seca, that's huge! I use track wheels with dedicated tires because I want the extra performance, life be damned. Where I live it's generally warm, but we have a few weeks of the year where temperatures are below 40F, and the tires I mentioned aren't supposed to be driven at those temperatures.
Third. Your streetable, all-temperature wheels become your rain tires. Why miss a track day when it's raining?
Four. It's nice to drop wheels off at a tire shop and not have to worry about them dropping a Lotus off a lift.
Sign me up! I'd probably run 18's on the street if they'd fit.
I'll have our track Evora off the lift this week sometime and get the Emira on there for some testing.
Will report back asap.
Greg to the rescue. Need to figure out what "needs" to be done to rear brake for 18s.
What "needs" to be done is that the actuator motor needs to be moved to fit an 18" wheel.
Doing so simply and reliably is the hard part. The motor drives a gearbox which in turn compresses the caliper. Since none of us amateurs or small companies have the resources to develop a new actuator, the low hanging fruit is to make some kind of geared adapter to put in between the motor and gearbox which moves the motor out of the way of the wheel. Doing so cheaply and reliably is a difficult task, and this being a safety critical component, you open up a whole can of worms by modifying it.
I don't have my car yet, and haven't been able to find a pic of the offending item- anyone have a pic?
What type of parking brake did the Evora use?
Answered one of my questions, here are details on the conventional internal drum parking brake used on the Evora.
That has been my experience with the F1s this year as well. I get a solid ~5 laps or so and then they feel very greasy. Looking to get a dedicated track setup soon.
Here's a pic of the offending item. Notice how close the motor housing is to the inside of the OEM 20" wheel.
Here's a WIlwood electric parking brake caliper with the motor that looks like it protrudes less. Maybe this or something like it could inspire modifications to the Emira unit, or maybe even replace it. Obviously, design work would be required to adapt a different caliper.
That's almost exactly what the Emira uses, just the black cylinder hanging off the bottom of the wilwood unit is more like clocked to be 'outside'.
Why not remove the parking brake for track use when you swap wheels and pads? You shouldn’t use a parking brake at the track anyway on a hot rotor. It really would open up a lot of options for 200tw tires. For manual cars just leave it in gear. Would that work?
It would work, and it'd probably throw a code or something, however, it's already enough of a pain to swap wheels for track days, I can't even imagine removing the parking brake each time. I have my limits.
I love my Emira, it has two things which annoy me; the seats and the electric parking brake.
